fly5150 wrote:One thing that I have experienced first hand that is a major problem when you run multiple controllers to axle hung motors is a motor failure situation. If you have one large controller feeding 4 motors and one does fail, you are unlikely to cook the other motors as the combined output of the controller will be split between the other three motors and not overload them. Now if you have 2 controllers feeding 4 motors, and one motor fails it WILL cook the other motor almost instantly, as it is sending double the amperage to one motor now. If you have 4 controllers feeding 4 motors then you should be ok, unless they are linked and shut down when one fails. I have experienced all of these situations over the years, and I have found that the simplest setup for troubleshooting, wiring, control and failures is one large controller like a 4QD-300, Sevcon, or Navitas controller.
as long as the motors are running in parallel, you will not cook the second motor in a one controller to two motor configuration as you describe.
the extra load may cause it to cook. but just simply losing one of the motors. (the impedance of the motor will not allow it any more current to flow at the same voltage)
if you are watching the current draw into each controller, you will see the current draw drop by~half when the motor circuits open up.
in fact you may even see current loads spike and the winding over heat and begin to short out and sending the controller into a fault state. (and from what i have researched, this is a killer for the 4qd controllers)
what you say will logically happen in a one controller to X motor configuration.. and we know it will not. again load may, not over current from losing a motor
now, if i am wrong, please show me with the numbers where i am wrong.
