Blomberg AAR-A or B truck plans
ChipsAhoy
Post by ChipsAhoy »
I'm looking to find a set of plans for building the Blomberg AAR Type "B" powered truck 7 1/2" guage. I can find casting available but I prefer to have plans for building them out of strap. The Type "A" will work I can modify them to accept the spring gang set. (not to be confused with the outside frame swinglink type).
aar 1.jpg (9.44 KiB) Viewed 2399 times
aar 2.jpg (5.74 KiB) Viewed 2399 times
EMD F7.jpg (14.4 KiB) Viewed 2399 times
Also looking for a providersupplier of F-7 A unit cab, 1.5 / 1.6 , that one I believe has the near verticle nose.
Steggy
Re: Blomberg AAR-A or B truck plans
Post by Steggy »
ChipsAhoy wrote:Also looking for a providersupplier of F-7 A unit cab, 1.5 / 1.6 , that one I believe has the near verticle nose.
I suggest you contact Dave Newell, fly5150 on this forum.
