Actually, two blocks are involved: a block governed by the signal and a "downline" block that follows.DianneB wrote:A 3 position signalling system requires monitoring the three blocks beyond the signal. If it is a bi-directional track, that doubles the complexity.
Semaphores explained?
Re: Semaphores explained?
Plus the block the train currently occupies.BigDumbDinosaur wrote:Actually, two blocks are involved: a block governed by the signal and a "downline" block that follows.
- ChuckHackett-844
I assume you mean the block just prior to the signal - if so, to my knowledge, most signal systems do not use this occupancy to determine the aspect on the signal being approached other than to support "Approach Lit" signals.DianneB wrote:Plus the block the train currently occupies.
In my system, the track just prior to the signal is used by the system as the "approach track". When a train is detected on the approach track the system checks the status of the block (occupied, other trains at other block entry points, priority of this signal, any dispatch holds in effect, etc.) to determine the primary aspect (Permitted or Stop) and uses the status of other tracks ('downline', etc.) to determine the actual aspect (Clear, Approach, Approach Distant, etc.).
Regards,
Owner, MiniRail Solutions, LLC, RR Signal Systems (http://www.MiniRailSolutions.com)
No, Dianne. Only two blocks affect a given signal in a basic ABS using three aspect signals, "basic" meaning no APB or other complications. For discussion's sake, I'll refer to those blocks as "home" and "downline." It will be assumed that only one train is in the signaled territory.DianneB wrote:Plus the block the train currently occupies.BigDumbDinosaur wrote:Actually, two blocks are involved: a block governed by the signal and a "downline" block that follows.
When a train enters the home block the "governing signal" changes to STOP. As the train proceeds and enters the downline block, nothing happens until the last wheelset leaves the home block. At that time, the governing signal will change to APPROACH. As the train continues, its last wheelset will eventually leave the downline block, at which time the governing signal will change to CLEAR. Hence only two blocks affected the governing signal.
