Alco AAR class B trucks
Moderators: Harold_V, WJH
Glenn Brooks
Re: Alco AAR class B trucks
Post by Glenn Brooks » Sat Dec 30, 2017 12:49 am
Looking really good. It’s always a pleasure to see such detail crafted into the scale models of this size.
OddDuck
Post by OddDuck » Fri Jan 05, 2018 3:02 pm
The shop finally warmed up enough to do some work, so I decided to square up the journal boxes and clean up the equalizer bars and lower spring pockets.
I'm very happy with how everything is fitting up, the sequence I used to square up the boxes actually worked, and the lower spring pockets match up with the uppers. I didn't turn the bores yet, I haven't decided what I am going to use for bearings yet.
"If you took the bones out they wouldn't be crunchy!" -Monty Python's Flying Circus
alco2350
Post by alco2350 » Fri Jan 05, 2018 9:09 pm
OddDuck wrote:The shop finally warmed up enough to do some work, so I decided to square up the journal boxes and clean up the equalizer bars and lower spring pockets.
Those look really nice! I am way to familiar with that truck as I used to have to do traction motor replacements with nothing but two forklifts. Lift the loco, roll out the truck, flip it upside down, flip out the traction motors and axles, and so on. This was on Alco C-420s.
Britt
Sent from my SM-N950U using Tapatalk
OddDuck
Post by OddDuck » Fri Jan 05, 2018 9:26 pm
Thanks! Hopefully I'm getting them reasonably accurate. The weather is supposed to moderate a bit next week, so I may actually get some casting done for some sets, at least the rest of the castings needed for the second half of the pair. I have to cast some wheels (in aluminum for just a test truck) so I can see how it sits.
This first set is possibly going to go under (at some point) a CN Alco FA1. That should be a challenge to cast the nose.
alco2350
Post by alco2350 » Fri Jan 05, 2018 9:29 pm
Are you going to model the axle alternator?
Britt
OddDuck
Post by OddDuck » Fri Jan 05, 2018 9:35 pm
Not planning to, the bolster is made to mount a motor directly underneath it, chain drive to one or both axles. There should be enough room that if someone wanted to use axle mounted motors they could. The bolster is not modeled after the original, it's a simplified one piece unit.
alco2350
Post by alco2350 » Fri Jan 05, 2018 9:38 pm
I meant the axle alternators, they usually attach to the fireman's side of the truck, and are splined to each axle, outboard of the journal. They provide axle rpm to the wheel slip system.
Britt
OddDuck
Post by OddDuck » Fri Jan 05, 2018 11:10 pm
Is that the rectangular doohickey on the end of the bearing housing with the hose coming off it? If so, yes, they are on the same pattern as the journal caps. Haven't gotten to that level of "putting it together" yet.
alco2350
Post by alco2350 » Fri Jan 05, 2018 11:26 pm
Yep, that's it. The alternators have a spade that fits into the end of the axle.
Britt
OddDuck
Post by OddDuck » Sat Jan 06, 2018 12:29 am
Ok, thought they were part of an lubrication system or something. You learn something every day.
Erskine Tramway
Post by Erskine Tramway » Sat Jan 06, 2018 12:01 pm
Our coal GE's, both U30's and C30's, used the same kind of alternator set-up. It also gave a reference speed for running the "Pacesetter" speed control we used when loading coal.
Mike
OddDuck
Post by OddDuck » Tue Jan 09, 2018 3:22 pm
Mock up is more or less complete, I'm very happy with how it came out. I had one aluminum wheel and the pattern for it, so I used them without an axle to check the look. And, the alternators are there. So besides a few tweaks to the patterns and writing up some basic instructions they are ready for prime time. The weather is supposed to moderate temperature wise over the next few days so I'm going to start casting components.
