Milwaukee Road # Conflict
Here is a good one for you guys...same #, definitely not the same locomotive.
The black and white pic was taken in my area years ago and appears to be an SD9 or GP9 to me, and when searching for #532 to see better pictures of her this SD10 keeps coming up?
Re: Milwaukee Road # Conflict
I believe it's the same loco rebuilt with a chopped nose, ditch lights etc.
John Brock
- Erskine Tramway
That would be my guess. We had an SD9, #6158, that got in a wreck, and they put a new cab and chopped nose on it. The last time I had an SD9 on a Local, the number on the call sheet was 6158. It was after the Sani Flush took over, and I figured it was a re-numbering. Turned out to be the actual 6158, and I was like a kid in the candy store, switching with a real SD9. The motor was older than my two crewmen
Mike
Former Locomotive Engineer and Designer, Sandley Light Railway Equipment Works, Inc. and Riverside & Great Northern Railway 1962-77
BN RR Locomotive Engineer 1977-2014, Retired
The short line railroad that runs around where I live has about 6 locomotives that were done that way. They were originally high-nose GP-9 locomotives that were cut down and had a big window added in the middle just like your pictures show. If you look at them from the side, and you know what to look for, you can tell that they've been cut down because the shape of the nose and length is just a little bit different than ones that were low-nose to begin with.
Also: Love that picture of the 532 in front of that factory. That looks like about a 1962 Chevrolet truck in the background there.
Very interesting, from the front of the cab back it does look the same with the exception of the ram horns thing on the top and the nose does look a bit funny.
The first picture of the SD9 on the bridge has a bit of a story. As a kid I'd go visit my great aunt in Everson, WA with my mom and we'd drive past this every time. If I remember correctly, the MR was having financial troubles and this line wasn't used much anymore, I have only a couple memories of seeing a train on this bridge as a kid. Then the coup-de-grace came when some kids set the bridge on fire. It was blocked off with some warning signs and train traffic obviously ceased. I remember asking my mom about the trains whenever I'd see the bridge and she'd tell me there wasn't going to be anymore and that they weren't going to fix the bridge. The bridge was then demo'd several years later and this is one of the only pictures I was able to dig up of it online.
Pontiacguy1, yeah that is a cool picture, I figured the truck for a 63 Chev just as a guess. I'm curious to know what factory/mill that was. The Port Angeles location has me thinking a lumber mill maybe?
The factory in the background has a sign visible for "Crown Zellerback."
The make (made?) paper products.
http://www.historylink.org/File/7475
It's a paper mill, still open today although it has changed hands several times.
1960 Chevy P/U
