yes, but they will been to setup to use a driveshaft like a mechanical setup
the motor would be mounted in the body with a belt or chain drive down to the driveshaft
Perhaps a bit of a typo?
yes, a clear case of brain running faster then my fingers trying to comment when i should be working
Those right-angle drives appear to be Tolomatic gearboxes. You would use an arrangement like this if a single traction motor is to be mounted inside the locomotive.
You could. The brakes on my F7 and the control (riding) car are Tolomatic calipers running on cut-down go-cart rotors. There are two calipers on the locomotive and four on the control car. That's a couple hundred dollars in brake parts.
