8hp vs 16 hp
Moderators: Harold_V, WJH
Nik3v
Re: 8hp vs 16 hp
Post by Nik3v » Fri Jan 18, 2019 10:33 am
Well,
At least I have turn outs in my track work and not switches.
I do know about the pipe fittings. This is the way I received it and I will be replacing them. That’s one of the reasons for the original question. So I would know what fittings to order.
Most likely going to remove one oily engine.
Nik3v
Erskine Tramway
Re: 8hp vs 16 hp
Post by Erskine Tramway » Fri Jan 18, 2019 11:07 am
Well,
Nik3v
Well....if we're getting pedantic, you have both :D The switch is the track assembly. The turnout is the curved side of a switch that 'turns out', and is usually speed restricted. They are shown in the Company's 'Timetable and Special Instructions' under 'Speeds through turnouts'. The operative word being 'through' and not 'over', the curved side has a speed limit, but the straight side is full track speed. We always called them switches, as in 'Number 1 Track switch', or 'power witches, never turnouts, anyway.
And, if we are going to 'get in the weeds' about it, what you have is an 'Hydrostatic' drive, not Hydraulic. Hydrostatic is pump to motor, Hydraulic used to be called 'Fluid drive', when I was a kid, referring to Automatic transmissions in cars.
I'm not intending to be insulting, so don't take it that way, but if we're going to talk about things, proper terminology is important, so that everybody is on the same page :wink:
Mike
Nik3v
Re: 8hp vs 16 hp
Post by Nik3v » Fri Jan 18, 2019 11:29 am
No offense taken. Just brought to mind the H.O. Discussions about switches being an electrical item.
I only just recently learned about the schedule 40 pipe not being suitable and it was a thread on here I believe.
Did not know about the hydrostatic drive. Always thought hydrostatic meant it was all one unit. Pump and drive in one as opposed to separate.
So I guess technically the travel motors on a large excavator are still a form of hydrostatic drive.
I appreciate these forums. I learn something almost every time I visit.
I have lots of track work this summer because I didn’t know to put the screws in the ties like this .’ ‘. Instead of •• ••. Now I understand why I’ve had so much creep in my track.
These boards are full of good information.
Nik3v
rkcarguy
Re: 8hp vs 16 hp
Post by rkcarguy » Fri Jan 18, 2019 11:52 am
The 1/2" fittings are typically used for one pump and hydraulic motors in "series", so there is no doubt that is the pinch point in your flow.
Hydraulic pressures should run in the 1400-1800 PSI range when you find a hill and are moving some weight, so those pipe fittings are a big blowout waiting to happen. Those are typically rated around 300 PSI only. Hydraulic fittings will be forged or extra thick wall stainless(we use some seamless schedule 80 stainless fittings in projects at work that are rated to 5000 PSI).
You should see some efficiency improvement over how it is now on one engine, with all that T piping mess removed.
Nik3v
Re: 8hp vs 16 hp
Post by Nik3v » Fri Jan 18, 2019 12:07 pm
There’s something I hadn’t even thought about. These are set up in parallel with a tee and lines to each truck. Would plumbing them in series be a better choice? I do understand the extra restrictions in elbows, tees, and such. I know about electric in series and parallel, but not so much in fluid.
Nik3v
BigDumbDinosaur
Re: 8hp vs 16 hp
Post by BigDumbDinosaur » Fri Jan 18, 2019 12:09 pm
Harold_V wrote:
Fri Jan 18, 2019 2:26 am
BigDumbDinosaur wrote:
Fri Jan 18, 2019 2:01 am
Not to be too pedantic, but the correct term for those two oily things with the fins that make noise and horsepower is "engine," not "motor." :D
In mechanical engineering, a machine that converts the chemical energy of fuel into kinetic energy is called an engine or prime mover. A machine that converts potential energy to kinetic energy is called a motor.
Thanks for that. All too many refer to the engine in an automobile as a "motor" (which would be correct for electric automobiles). Likely due to the line that got fuzzed long ago when motorcycles were invented. It's a little more comfortable to say than enginecycle. :-)
A trauma nurse I dated years ago used to refer to a motorcycle as the quickest way to the emergency room—as a patient. :shock:
Well,
I've met one or two witches over the years, but was not sure if they were manually operated or had power assist. :D
Furthermore, an automobile's automatic transmission has a hydrodynamic torque multiplier, which is that oil-filled, doughnut-shaped thing everyone (including me) calls a "torque converter."
There is a topic somewhere around here on use of proper English in one's posts. It was interesting to read some of the excuses about why this person or that couldn't post in grammatically-correct English. :)
BigDumbDinosaur
Re: 8hp vs 16 hp
Post by BigDumbDinosaur » Fri Jan 18, 2019 12:13 pm
Nik3v
Series is customary in model locomotives. If the motors are in parallel there will be more of a tendency for one truck to slip during startup or on upgrades. With the motors in series, both trucks are forced to run at the same speed, assuming the motors are the same displacement.
In my F7, I have it plumbed so the oil flow is from the pump to the reverser valve, to the rear truck, to the front truck and back to the reverser valve. "Rear truck" is relative to the direction of travel, not the locomotive.
BigDumbDinosaur
Re: 8hp vs 16 hp
Post by BigDumbDinosaur » Fri Jan 18, 2019 12:16 pm
I was going to attach some Parker catalogs for you but the Chaski board software apparently won't allow the upload of a PDF file.
warmstrong1955
Re: 8hp vs 16 hp
Post by warmstrong1955 » Fri Jan 18, 2019 12:56 pm
Not in the weeds....just equipment nomenclature.....
Hydraulic drive refers to fixed displacement systems, ie, generally; gear or vane pumps & motors
Hydrostatic drive refers to variable displacement systems, ie; piston pumps using either fixed or variable displacement motors
Torque converter, is a combination of a fluid coupling, with a torque multiplier. Since it's what the manufacturers call the beast, and have for years, I'll stick with their name for it.
Nik3v
Re: 8hp vs 16 hp
Post by Nik3v » Fri Jan 18, 2019 1:20 pm
Thanks guys. This will greatly simplify my plumbing.
I will look up the Parker catalogues you mentioned.
warmstrong1955
Re: 8hp vs 16 hp
Post by warmstrong1955 » Fri Jan 18, 2019 2:25 pm
Here ya go.....Parker.....
https://www.parker.com/literature/Tube% ... _Cover.pdf
I'm an Aeroquip fan, more variety, in spite of being conquered by the Eaton Gods, so here is that.....
https://www.eaton.com/ecm/groups/public ... 479318.pdf
Adapters start at page 198
Re: 8hp vs 16 hp
Post by Harold_V » Fri Jan 18, 2019 4:39 pm
Worked for me. As a young lad, one with no bike experience aside from having a Doodlebug as a kid, my '63 TR-6, purchased new, landed me in the hospital with a concussion and a dislocated clavicle.
I sold the bike.
