Painting graphics on plywood - advice
Re: Painting graphics on plywood - advice
I had this problem with some large decals I applied to a race car years ago, the backer paper just wouldn't let go of the vinyl even though it felt like I had decent adhesion to the cars body. I ended up making a solution of dish washing soap ( I had lemon Joy) and warm water and sprayed it onto the backing several times and was able to get it to let go and leave the decal on the car.
- makinsmoke
Benjamin,
You have to burnish the stencil onto the surface with the backer on. I used the end of a model paintbrush. The round wood end.
- Benjamin Maggi
I burnished and burnished and burnished. I pushed it into the wood as hard as I could. Then, when I removed the backer the stencil came off too. The plywood just wasn't smooth enough to give the stencil enough surface area to make a firm grip that could overcome the pull of removing the backer. I tried multiple stencils in multiple places with the same result.
I might just paint a piece of aluminum and then stencil that, and then screw the decorated metal onto the side of the car. It is only a bulkhead riding car and not a detailed freight car.
That's what I've done. Works fine over time.Benjamin Maggi wrote: ↑Fri Aug 30, 2019 9:22 am [snip]
RN
- makinsmoke
You might try spray Spar Urethane in rattle can.
That’s what I top coat everything wood with.
It comes in gloss, satin and flat.
Just like the model guys, use a coat of gloss and put your stencils/decals on that layer. Topcoat with satin.
