Good morning
I recently inherited (for the lack of a better word) 60 pieces of aluminum rail from my father, who got it from a friend about a decade ago. This particular rail is metric. Yep, metric. I tracked down (no pun intended) the original supplier in the UK, but they refuse to ship to the US for "insurance reasons." The rail I have is 21mm tall, and the base is 19mm. I know that I can make some compromise joints and fit it up to 1" rail with some work, but I would like to find matching rail if I can. Anyone out there have some of this oddball metric rail laying around?
Looking for rail
Looking for rail
7.5" Allen Mogul
The railroad is almost done.
G. Augustus
Monte Rio, Ca.
G. Augustus
Monte Rio, Ca.
Re: Looking for rail
I am going to take a wild guess....There are probably two chances of finding that in the US.
John B
John B
Probably only at the well known supplier "Slim and None." I figured it would be unlikely, but asking is better than guessing.
7.5" Allen Mogul
G. Augustus
Monte Rio, Ca.
G. Augustus
Monte Rio, Ca.
I think you could probably find someone overseas somewhere else would make it, but they'd likely want you to order a very large quantity. I'd use it for a yard track, siding, or spur and make some adapter joiners, as commonly done in full scale trains.
If nothing turns up, you could easily make up some fish plates out of small bar stock. Mill one end shorter than the other to bolt the two different rail profiles together. Bit of shim under the shorter base and your good to go. This is a fairly common practice in the Grand Scales. Also the big boys did this all the time with different weights of rail on their mainline systems.
