Springs for RRSC 6 Wheel Passenger Car Trucks
dwilloughby
Post by dwilloughby »
I'm building a number of RRSC 6 wheel passenger car trucks. I have acquired dummy leaf spring sets and need some advise on the coil springs. I would like to have a progressive spring set similar to what is used by Real Trains. Any suggests as to the inner and outer springs would be appreciated. Thanks
Pennsy fan
Re: Springs for RRSC 6 Wheel Passenger Car Trucks
Post by Pennsy fan »
Give Jim Oetting a call, he has the right springs for these trucks.
david.
Trainman4602
Post by Trainman4602 »
Dean
This is what I use on my six wheeled trucks. I have a dummy set of leaf springs and I use an inner and an outer spring on the equalizer bar. I think you can see the two springs in the picture.
Kimball McGinley
Post by Kimball McGinley »
When nesting coil springs inside each other, it is best if they are wound opposite directions; one left, one right. That way the coils cannot ever get hung up on each other, or get one trapped in the other.
