fly wheel
This forum is for those individuals or small business to solicit requests for Service from those members of our group. Machining, Foundry work, Sheet Metal work etc. This site makes no guarranty of work or represenation by the users of this site. It merely attempts to provide a place to allow individuals the opportunity to meet and discuss needs and capabilities.
lotsasteam
fly wheel
Post by lotsasteam » Tue Dec 13, 2016 11:50 pm
building a hit n miss engine:Hoppy from Rahout germany (believe was made in GB) the parts are nice machined the only design flaw is the aluminium fly wheel which das not have the mass for a smooth run :I need 2 brass rings 140 mm OD 95 mm ID 15 mm wide ( cast iron will do also ) the rings will be loctite to the alu flywheel! Any body can give me a source or quote? Thanks in advance!
Re: fly wheel
Post by SteveM » Wed Dec 14, 2016 9:49 am
You might want to specify your location.
In fact, if you put it in your profile, it will appear under your name in every post.
ALCOSTEAM
Re: fly wheel
Post by ALCOSTEAM » Wed Dec 14, 2016 3:34 pm
Sourcing material to make these out of brass is going to be expensive. The best I could find 1" drops of 360 brass was about 75.00 each + shipping. Cast iron would be ok and only about 30.00 and shipping per piece. You might also look at steel as you can get pipe weld flanges with a big hole already in the middle fairly reasonable as well.
ctwo
Re: fly wheel
Post by ctwo » Wed Dec 14, 2016 3:54 pm
Could you cast lead around it?
redrocco
Re: fly wheel
Post by redrocco » Fri Jan 06, 2017 11:11 pm
I have two brass pipe flanges removed from some old 3" copper pipe that might work. The ID is 2.920" the OD would be 5.5" if they were turned down just enough to get rid of the 4 bolt holes and they are about .5" thick but would be more like .460 to .475 thick range after they were faced. In metric the finished part would be 95 mm ID and approximately 139.7 mm OD and 12 mm wide. Let me know if your intersted, i can just sell you the 2 flanges for $40 + shipping or if you want me to turn them down for you, and then they would be $100 + shipping for the pair.
Hears a pic of one of them.
lotsasteam
Re: fly wheel
Post by lotsasteam » Sat Jan 14, 2017 9:40 pm
Sounds ok to me i 'm away from home so give me a few days so i can x actly measure the id so i only need to ream it out a little to get a god press fit!
Thanks! Manfred
redrocco
Re: fly wheel
Post by redrocco » Tue Jan 17, 2017 5:09 pm
Sounds good to me, let me know what you want the ID turned to and I will leave as much as I can on the OD and thickness when I clean them up. I am guessing the shipping will be around $10 in the cont. USA.
