The Home Machinist!
It is currently Fri May 24, 2013 2:37 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2, 3  Next
Author Message
PostPosted: Fri Aug 03, 2012 5:58 pm
Offline
Dumb question:
Is it possible for a garage machinist with a Chinese mini-mill to machine mating surfaces precisely enough to achieve an oil-leak-proof joint without a gasket or seal of any type? How about using thick oil?
Jim
Top
 Profile
PostPosted: Fri Aug 03, 2012 6:53 pm
Offline
short answer...no
even if you could get the precision needed (unlikely) you most likely couldn't get the surface finish needed . Even the crankcase of my airplane used a silk thread to provide a "crush gasket" to seal
Top
 Profile
PostPosted: Fri Aug 03, 2012 8:20 pm
Offline
With machining only, I doubt it. Add a reasonable lapping plate, plus skill, and I think it can be done.
Round parts will need honing and lapping.
Any irregular surfaces, not a chance. (Without LOTS of hand work.)
Dave J.
_________________
Top
 Profile
PostPosted: Sat Aug 04, 2012 11:18 am
Offline
okay.....how about a thin layer of Vaseline squeezed when the joint is fastened with cap screws? the walls will be 31/32" tick, so that's a nice, wide joint. I really don't want to make grooves for o-rings or deal with gaskets. There will be no pressure - it's a rotary table - it's just for simple lubrication. Maybe a 5" rotary table does not even need constant lubrication?
Top
 Profile
PostPosted: Sat Aug 04, 2012 11:48 am
Offline
:-) I wonder if even gauge blocks wrung together would be "oil tight". :-)
...lew...
Top
 Profile
PostPosted: Sat Aug 04, 2012 12:25 pm
Offline
Use a thin film of orange silicone and install, that is what I use and works fine.
Richard W.
Top
 Profile
PostPosted: Sat Aug 04, 2012 1:03 pm
Offline
I've used Loctite 5452 for low pressure to high pressure hydraulics, for metal to metal fits. It'll even seal JIC fittings that have taken some hits, when you don't have the time, or the stuff to fix things right.
Bill
_________________
Top
 Profile
PostPosted: Sat Aug 04, 2012 1:13 pm
Offline
...lew...
I don't see why not. I have taken apart hydraulic pumps that had no seals execpt where the shaft enters. Just ground surfaces and bolted together.
Richard W.
Top
 Profile
PostPosted: Sat Aug 04, 2012 8:32 pm
Offline
I'm not sure I'd want to use something that is too thick in consistency. The reason is that I wouldn't want to interfere with the alignment of the base parts. I'm making this table so I can then make a high-precision worm gear for a go-to telescope. Any irregularities in the base or other components of the table would compromise the accuracy of the gear, which, in turn, would reveal itself in the inconsistency of accurately pointing to objects in the sky. Therefore, something that had a lighter consistency, such as Vaseline, would certainly squeeze out a lot better and only remain wherever there are voids. Tell me if my logic is messed up.
Top
 Profile
PostPosted: Sat Aug 04, 2012 9:59 pm
Offline
Vaseline is nothing but cosmoline with the sulphur removed. Its not intended for sealing anything. Silicone will squish out very thin as it would only remain in the low spots of the surface finish. I have peeled it off parts where it was so thin you could almost see through it. If that isn't good enough then cut grooves for an o-ring. Just remember if the groove isn't wide enough to allow the o-ring to compress with out filling up the groove completely, then your condition would be worse and warped parts may be the result.
Richard W.
Top
 Profile
PostPosted: Sat Aug 04, 2012 11:35 pm
Offline
Quote:
Vaseline is nothing but cosmoline with the sulphur removed. Its not intended for sealing anything. Silicone will squish out very thing as it would only remain in the low spots. I have peeled it of parts where it was so thinn you could almost see through it. If that isn't good enough then cut grooves for an o-ring. Just remember if the groove isn't wide enough to allow the o-ring to compress then your condition would be worse and warped parts may be the result.
Top
 Profile
PostPosted: Mon Aug 06, 2012 10:26 pm
Offline
Sealing tight metal to metal joints >>>> Loctite 574 or 518
Joe B
Top
 Profile
Who is online
Users browsing this forum: Yahoo [Bot] and 4 guests
Search for:
Jump to:
