A nice way to store reamers??
dirtcrasher1
Post by dirtcrasher1 » Tue Feb 13, 2018 10:30 pm
Hello, I thought I post this question last night, but it's not listed.
Anyhow, I went a little crazy buying steel chucking reamers so I could have a full set.
Most of them are sharp, but they don't have a tube. I need a way to store singles or a pack of 6 maybe.
Could someone suggest a tube or an in/out fit type of telescopic cardboard tubing, I'm not sure...
I don't know what to call what I need or where to get them. Of course I won't be able to get them sized perfect but I need a couple hundred that can hold a 9" reamer, some 12" long and maybe some 14 or 16"s long.
Thanks for any help....
choprboy
Re: A nice way to store reamers??
Post by choprboy » Wed Feb 14, 2018 12:20 am
I think you are just looking for telescoping endmill/drill cases? Apparently McMaster has some, but it looks like its mostly bulk from a manufacturer other than that (bottom of page):
https://www.mcmaster.com/#drill-bit-boxes/=ghmu2q
On the other hand, why not just use a plain plastic or cardboard shipping tube from Uline:
https://www.uline.com/BL_3651/Clear-Plastic-Tubes
https://www.uline.com/CustomProduct/Bro ... diameter=1
Or you can get really fancy:
https://0x7d.com/2016/compact-end-mill-case/
spro
Post by spro » Wed Feb 14, 2018 1:00 am
I could send you a case of "urgent request" envelopes.
spro
Post by spro » Wed Feb 14, 2018 1:27 am
The only thing which could strike and harm another cutting edge would be another one. I wouldn't trust an envelope as it may have acid or degradable substance. Yes I agree that reamers should be separate.
earlgo
Post by earlgo » Wed Feb 14, 2018 10:12 am
Until you find the right solution, you could roll the reamers in oiled waxed paper and secure it with a twist tie or piece of string.
I have a number of older tools wrapped in oiled paper straight from a manufacturer.
--earlgo
David Merrill
Post by David Merrill » Wed Feb 14, 2018 1:36 pm
How about some clear vinyl hose of various sizes purchased in bulk reels and cut to needed lengths. Transparent, soft and the reamer would hold the coil curvature sort of straight. Keep in drawers with dividers.
https://www.amazon.com/s/ref=nb_sb_ss_c ... ICUAYK60Y6
David Merrill
SteveM
Post by SteveM » Wed Feb 14, 2018 2:22 pm
I have one of these for fractional reamers by 64ths and a second one for popular sizes in pairs as over/under:
Because you always have more than one of many sizes, I also have one of these:
ctwo
Post by ctwo » Wed Feb 14, 2018 3:42 pm
I like the hose idea, maybe pex pipe.
dirtcrasher1
Post by dirtcrasher1 » Wed Feb 14, 2018 11:40 pm
Thanks for the suggestions. I have a hundred to sell right off the rip, so I'd like to put them in a nice container.
It was fine to roll them up in newspaper, there's no moisture issue or anything, but, there's about 50 .4995 reamers just to start with :D
And a 45 lb box full on the way, I'll get a few pics up...
wlw-19958
Post by wlw-19958 » Thu Feb 15, 2018 12:45 am
Hi There,
It would be "classy" to wrap them up in VCI paper.
Good Luck!
-Blue Chips-
Webb
tornitore45
Post by tornitore45 » Thu Feb 15, 2018 11:49 am
The way I do it is to drill appropriate size holes in a block of wood and stick them vertically.
Then I place a cork with a sanded face bearing the measure because is too hard to read it off the shank. The cork cleans and retains oil on the cutting edges.
I have no problem acquiring corks, if you get my drift.
Mauro Gaetano
in Austin TX
ehughes
Post by ehughes » Fri Feb 16, 2018 4:38 pm
Hello, I have used polyethylene mesh sleeve (I used the elastic kind) from McMaster-Carr: Earl
