Way oil for DoAll 6x18 Manual Feed
sierevello
Post by sierevello » Thu Feb 22, 2018 3:47 pm
Any suggestions on a way oil for my manual Doall 6x18? I have thought about Mobil DTE24 and also Vacuoline 1405. If you have any input please let me know. I thought tackifiers in Vacuoline 1405 might cause some stickiness.
Thanks, Steve
spro
Re: Way oil for DoAll 6x18 Manual Feed
Post by spro » Thu Feb 22, 2018 7:35 pm
Yes. Not all sizes of lathes require way oil. It comes to the pressure mass of the saddle, size of ways. If it seems too sticky, then it probably is.
wlw-19958
Post by wlw-19958 » Thu Feb 22, 2018 7:49 pm
Hi There,
Does the manual have a specification for lubrication?
Good Luck!
-Blue Chips-
Webb
RMinMN
Post by RMinMN » Fri Feb 23, 2018 8:58 am
Any oil is better than no oil. There may be a best oil for you lathe ways and it might be specified in an owners manual. Using nothing but the right oil will ensure longevity of the ways in hard use for industry. if you are a hobbyist, you lathe probably won't be used all day, every day for years. You get to choose the lubrication that suits your use and expected lifetime wear that is acceptable.
GlennW
Post by GlennW » Fri Feb 23, 2018 9:37 am
It's a surface grinder, not a lathe.
Why not Vactra #2?
spro
Post by spro » Fri Feb 23, 2018 10:00 am
:oops: Guys. I blew that, thinking it was a rebadged lathe.
sierevello
Post by sierevello » Fri Feb 23, 2018 11:03 am
Glenn,
Vactra #2 is ISO68 and seems to cause the table to "float" b/c of the viscosity causing some finish problems.
I was looking for an ISO32 oil to try to cut down on that issue. I could go to a Vactra #1 but it is hard to find in anything less than 5 Gallon pails. Best price I have found is $89 and $28 to ship.
Thanks,
GlennW
Post by GlennW » Fri Feb 23, 2018 11:34 am
That sounds a bit odd.
Is it a rack and pinion drive table?
I'm able to buy Vacuoline 1409 in gallon quantity from Neuco Supply in Florida, but use it on my lathe only. You might talk to them
Grinders get Vactra #2.
Mr Ron
Post by Mr Ron » Fri Feb 23, 2018 12:42 pm
A local machine shop might sell you some or even give it to you free.
Mr.Ron from South Mississippi
sierevello
Post by sierevello » Fri Feb 23, 2018 2:34 pm
Glenn,
Yes it is a rack and pinion drive table.
GlennW
Post by GlennW » Fri Feb 23, 2018 4:15 pm
Rack and pinion can sometimes print a pattern in the surface.
