Need to buy drills
Need to buy drills
I need to buy a set of HSS, bright, 118°, jobbers length, fractional twist drills. I checked the MSC catalog and they list many different manufacturers and many different prices. Of the following choices I've contemplated are Hertel, Precision twist Drill, Chicago-Latrobe, Cleveland, Triumph and Interstate. Others I am aware of are Brubacker, Dormer and Onskog. I'm tired of using cheap Chinese drill bits that don't cut well, are not straight and dull quickly. Can you give me your recommendations on the drill bits that work best for you? These will be for general purpose drilling of all metals; no SS or tool steels. I will be looking for number size drill bits also in the future. I have an old 29 piece set of drill bits that are high quality, but I don't know what make they are.
Mr.Ron from South Mississippi
Re: Need to buy drills
I find Precision, CL, Cleveland, and Triumph to all be good, but they may all be owned by the same parent company.
- refinery mike
I have used Chicago Latrobe and found them quite good. in addition to the others mentioned.
- Frank Ford
If you haven't tried them, get hold of some 135 degree split point drills.
They hardly ever "walk" at all, and penetrate much more easily for regular drilling, often eliminating the need for pilot drilling in larger sizes.
Once I'd had some for a few months, I literally gave away all my other drill sets!
Mine are mostly Triumph
The split points (on the right) cut right to the center where the regular drill has to force it way in, and the difference is nothing short of amazing:
Cheers,
Frank Ford
Frank Ford
- warmstrong1955
Don't count out Hertel. I've bought many, and done quite well. I drill a lot of alloys, primarily 4140/4142.
Given your specs, I'd get a Norseman set from Harry Epstein's. I have this set and am happy with it (except I wish I'd gotten the bigger set)
http://store.harryepstein.com/cp/DrillBitSets/J-29.html
Or you could go all in and get your number/letter sets as well as 1/64 increments...
http://store.harryepstein.com/cp/DrillB ... J-115.html
Yes I'm another vote for the 135* split point bits. I have both jobber and stubby 115 piece sets in 135*
www.chaski.com
I also agree on the 135* split points. Particularly for steels, very hard to beat. I tend to go for PTD, but CLE and many others are good. Just be aware that some have multiple target audiences, and "consumer grade" may not be up to "industrial grade". Like Frank, I've learned the value of good tools that work well, but unlike Frank I'm cheap and I tend not to get rid of the "bad" bits. There is always the use for which I don't want to consume (and dull) the good stuff. When drilling fiberglass, concrete board, or even stuff like sheetrock, I reach for my cheap bits that I keep around for just such occasions. I also tend to reach for them when I need a custom point for some purpose. I've made brad points, non-hogging (like for brass), and even counter bore bits like that.
Thank you all for your response. I would say that I work with aluminum about 90% of the time, so that is why I choose 118° bits. I thought 135° bits were for hard steels, not aluminum.
118 is the general drill bit angle that hits within the acceptable range of most common metals. 135 will work with aluminum or steel, but tends to work a LOT better with steels, whereas in aluminum it really doesn't seem to make much difference that I've noticed.
The 118° drills have a thinner web, therefore have a bit more chip clearance. I prefer them for aluminum.
This may help.
Enco has 10% off and free shipping on orders of $99.00 or more.
Enter Both Promo Codes NOVDS & NVUPS | Offer Valid Until 12/1/14
