No problem I can put the flats on, but was just asking.
I drilled & tapped this pusher that I had made long ago:
Something that I made a while ago & had to fiddle w/ each can I crushed:
Arbor Press Improvement
Re: Arbor Press Improvement
Love it !
In hindsight the "crusher" attachment doesn't have to be as tall. Nor made out of 3 pieces. A piece of mat'l 1" thick, bored press down on the rim & clear the side of the can should be sufficient. A threaded hole in the top would replace the nut.randyc wrote:Love it !
Here's a sketch for those of you that wants to make a can crusher.
It fits current Bud' (US & Canadian versions), Coca-Cola, Sun Drop & Country Time cans.
Much simpler, thanks for the sketch !revrnd wrote:Here's a sketch for those of you that wants to make a can crusher.
