Here Goes
- SteveHGraham
Re: Here Goes
What is that big flat grey thing under the machines?
Re: Here Goes
Nice mill, About a 8" X 32"table size? If so I have about the same mill and mine's got the power feeds on the spindle like yours. Most likely your's and mine were both built by Bemato in Taiwan since they make the Jet mills that are also the same table size.
Pete
Pete
Re: Here Goes
I've struggled to understand posting pictures. I know this isn't optimum and I'm working on a better solution AND open to suggestions:) The mill in last post is 9x46 purchased in 2013. Next is my 4th lathe in less than 4 years. It's courtesy of a generous friend who ended with TWO new mills and passed one along as a sweet heart deal. In the background you can see my drill press and HF round column mill. Against the far wall is the flat space I can't seem to keep clean.
Re: Here Goes
The mill is 9x49 Shop Fox. No complaints given my "skill level".
- SteveHGraham
Re: Here Goes
"Floor." "FLOOOOOOOOR."dcmus wrote:The gray stuff is "floor" I've worked without it but it sure is nice:)
I like floor. I wonder where I can get some.
- seal killer
Re: Here Goes
dcmus--
That's a great looking space! How are you going to heat and cool it?
--Bill
--Bill
You are what you write.
Re: Here Goes
Good question. I used fiberglass batts in the 8ft walls of large section. The 20x28 has a loft with C perlin joists above the dropped ceiling. I don't think there's insulation behind those walls so unsure what to do there. I plan to replace the sagging tiles and use batts in the ceiling. Once the 10x10 rollup door is installed in large section I'll frame and insulate the remaining wall and then have spray foam insulation for the remainder. I'm definitely open to suggestions if anyone wants to chime ine:)seal killer wrote:dcmus--
--Bill
Re: Here Goes
As for climate control..........I'm still studying that...........I'm in OK not AZ as the song says but it does get hot. Heating is not such a serious issue. A friend owns a motel and have considered 2 or 3 of the two way units he uses or the mini split units I hear discussed. Again I'm open to suggestions.
- seal killer
Re: Here Goes
dcmus--
Insulate it like crazy and then stick as much air conditioning on it as you can afford.
--Bill
--Bill
