dro for z axis
dro for z axis
There were a number of threads on adapting a digital calipers for the z axis on a mill but I am not able to get the correct words in the search mode to find it. Can anyone remember what is was"?
Re: dro for z axis
I don't know but I did that on my 9x49 import mill. Will shoot some pictures tomorrow.
Re: dro for z axis
Dro Quill kit for "z" axis with 6" travel
gets you some hits on quill readout kits.
----this is a #303-9304 digital readout for my mill quill ---seems like I paid about $28 to $33 each about 16 years ago and I bought 3 of them---but I don’t exactly remember where I got’m----quite likely was
http://archcity.net/Supplies5_Readouts_EdgeFind.html which showed'm at $56 1-18-2013
http://www.shars.com/products/view/2404 ... hine_Scale
---Shar’s price was listed as $77.95 1-18-2013
-the only issue I've had with the one I've used on my mill is one of the large buttons eventually fell out--so I had to make a flexible way to retain the button in place.
maybe you can get some ideas from this to mount a dial caliper.
-previously I had a Mitutoyo with really small buttons that were flush with the face surface and hard to push.
-this big button deal works really nice.
-I have had the one digital in use now for about 16 years---and only used one or two batteries.
-you might notice the bottom mount happens to be made of teflon with recessed fasteners.
-reason is---if you bang your forehead on the metal screws or bracket a time of two you'll probably come up with a "softer" lower mount yourself.
-I also used nylon mounting screws and nylon washers to totally insulate the digital unit from the mill housing----so I wouldn't ever have any electrical problems messing with the digital readout.
-I also had to bolt a piece of round bar stock teflon to the back of the movable digital display---to fit back into the up & down quill drive hole.
