Wiring a china drum switch
Randall Va
Post by Randall Va »
http://www.ebay.com/itm/60-Amp-Drum-Swi ... 1e9be60082
Anyone wired up one of these switches?I have a friend that has a 2hp lesson motor on his lathe and wants to reverse it,has no diagram of switch or motor!
Thanks Randall
www.chaski.com
J.Ramsey
Re: Wiring a china drum switch
Post by J.Ramsey »
From the Leeson website.
http://www.leeson.com/leeson/searchprod ... oductType=
Click upper right "view connection".
Switch may have diagram under the cover?
Randall Va
Thanks J
Randall
www.chaski.com
spro
Post by spro »
Some of these motors, see "CC" on that emblem , are not made to run in reverse. I had a post or thread here about drum switches. I was wondering if the newer were any good as compared to different manufacturers of different ones. You can't blame the switch unless it is a reversible motor.
Bob D.
Post by Bob D. »
The photo of the motor tag you posted clearly shows the wiring diagram and states it's a reversible motor. Just swap leads 5 & 8 to change rotation.
Bob D.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
spro
Post by spro »
Of course. Sorry to jump there.
Randall Va
Bob D. wrote:The photo of the motor tag you posted clearly shows the wiring diagram and states it's a reversible motor. Just swap leads 5 & 8 to change rotation.
Bob D.
Got it wired,here's how
www.chaski.com
spro
Post by spro »
Super. The dotted lines are jumpers. I never found my diagram but yours is fine. How does the quality of that switch look to you? Were they skimpy on copper?
Randall Va
spro wrote:Super. The dotted lines are jumpers. I never found my diagram but yours is fine. How does the quality of that switch look to you? Were they skimpy on copper?
its sure not top qualty and I don't see alot of copper its on my friends lathe ,guess we'll see how it last's
Randall
www.chaski.com
