Need A Little Help With Drill I.D.
McKay59AB
Post by McKay59AB » Fri Dec 18, 2015 2:46 pm
I have had these drills for years and have worked great in aluminum. I want to purchase a few more with a larger size (+.750), but I have cruised some tool catalogs and cannot seem to locate any. Could somebody shed some light on the kind of drill this is? Can these be sharpened in my home shop,or do they have to be sent out? Here is a picture. Thanks for any and all help.
ctwo
Re: Need A Little Help With Drill I.D.
Post by ctwo » Fri Dec 18, 2015 3:08 pm
looks like a counterbore
mklotz
Post by mklotz » Fri Dec 18, 2015 3:27 pm
I know them as "bullet point" or "pilot point" drill bits. Googling on those terms produces lots of hits. However, I've never seen one larger than 1/2".
Regards, Marv
Home Shop Freeware
sch
Post by sch » Fri Dec 18, 2015 5:49 pm
Counter bores are generally shorter, designed to sink a SHCS head below or at surface level. The narrow part fits in the hole to be threaded as a
pilot (or drills the shank hole) and the larger part makes a slightly oversized hole for the SHCS head. The OP drills look like aluminum helixed
pilot point drills. Counter bores are sized for specific SHCS sizes.
10KPete
Post by 10KPete » Fri Dec 18, 2015 7:01 pm
Looking closely, there is no flute relief on the pilots and at least one has a diametric relief where the pilot joins the drill portion.
The pilots are ground as cylinders with no relief.
Most definitely pilot drills intended for enlarging an existing hole, or part of a hole anyway.
Never intended for drilling new holes!
Pete
Just tryin'
McKay59AB
Post by McKay59AB » Fri Dec 18, 2015 9:20 pm
That is correct Pete, I never use these drills without first drilling the correct pilot. I just finished drilling 24 holes .7049 in aluminum and the drill struggled. I think the drill was made at Precision Twist Drill. The I.D. on one of them is "PTD HS USA L#775". It looks as if they are out of business? Are there any attachments made that will fit in a lathe to sharpen this kind of drill?
10KPete
Post by 10KPete » Fri Dec 18, 2015 9:46 pm
To my knowledge PTD is still in business. I haven't checked. Sharpening those drills can't be done on your normal
Drill Doctor type as you know. It takes a cutter grinder to get to the ends of the flutes behind the pilot. Any tool
and cutter grinding shop, that does end mills, c'sinks, and the like should be able to do those and be able to make
any size pilot you want on new drills. I've never seen them just sold as stock, but have had dozens made for me
over the years.
Cheers,
Pete
Just tryin'
Post by GlennW » Fri Dec 18, 2015 10:48 pm
NAS937 drills are similar to the ones being discussed.
http://www.panamericantool.com/piloted- ... s-937.html
I have a bunch of them just like the ones being discussed, and will look tomorrow to see if there are and manufacturers names on them.
Russ Hanscom
Post by Russ Hanscom » Fri Dec 18, 2015 11:15 pm
These would be treated as specialty drills, and priced accordingly. I have a large bunch that were purchased from Boeing Surplus in Seattle while they were still open to the public. Probably purchased to special requirements and not standard catalog items. Really nice to use when they fit a requirement I have.
Sharpening the step requires special equipment not normally found in the home shop; since I got mine for cents on the dollar and have many, I make no effort to sharpen them.
reggie_obe
Post by reggie_obe » Fri Dec 18, 2015 11:37 pm
Those are subland sometimes called step drills.
curtis cutter
Post by curtis cutter » Sat Dec 19, 2015 1:19 am
Russ Hanscom wrote:These would be treated as specialty drills, and priced accordingly. I have a large bunch that were purchased from Boeing Surplus in Seattle while they were still open to the public. Probably purchased to special requirements and not standard catalog items. Really nice to use when they fit a requirement I have.
That takes me back. I used to go to Boeing Surplus in Kent probably once a week. Good stuff by the pound.
Gregg
earlgo
Post by earlgo » Sat Dec 19, 2015 10:09 am
Re: sharpening.
IF you have a Dumore or similar die grinder and a means to attach it to your lathe compound/tool post you could possibly sharpen the cutting edges of the drills. I don't think a Dremel would have enough horse-power.
You would need to index the drill properly and that can be done by measuring the OD of your chuck cutting a strip of (paper) marking off 3, 4, or whatever spaces and taping it to the chuck. A pointer attached somewhere would be the index finger.
Enough setup and fooling around should get you where you want to be.
Before I bought the Delta Toolmaker, I made a counter-bore and sharpened it in this manner.
--earlgo
