Mysterious "1/2 Axis" Displayed on DRO
Post by SteveHGraham » Sat Apr 02, 2016 12:29 pm
I have a Griffin GF800 (Lih Rurng) DRO on my lathe. The danged thing refuses to zero on the x axis. It keeps saying "1/2 axis" on the display. Y is fine.
While I'm digging through the manual, can someone give me a clue what this means and how to clear it?
Re: Mysterious "1/2 Axis" Displayed on DRO
Post by SteveHGraham » Sat Apr 02, 2016 1:06 pm
It looks like I found the answer. You have to push random buttons while cursing in a loud voice.
Apparently you don't have to go past the S word.
Rick
Post by Rick » Sat Apr 02, 2016 1:08 pm
I have found that if you use your middle finger instead of your index finger to push the buttons not as many curse words are required
Rick
Magicniner
Post by Magicniner » Sat Apr 02, 2016 1:09 pm
You have a Y axis on your lathe, that's a posh one!
choprboy
Post by choprboy » Sat Apr 02, 2016 7:51 pm
Reading the manual, it looks like that is part of the center finding function. "X" to exit.
3.5 Search the center of work-piece
Function: Divide the current display value by 2. With this function, you can set origin at the center of the work-piece.
Example: Set up the central point of X-axis for the work piece.
Operating steps:
1. Return to normal monitor state.
2. Locate to your first position (one edge of your work-piece) and press [X0] to zero X-axis.
3. Locate to the second position (the other edge of the work-piece) and press [1/2] to locate the central point. The message-window displays “1/2 AXIS”.
4. Press [X], you have set up the central find of X-axis.
5. Move until the display value of X-axis is “0”and it is the central of the work-piece.
Post by SteveHGraham » Sat Apr 02, 2016 9:04 pm
Thank you. I can't find that stupid manual anywhere. I will see if I can put this to use.
choprboy
Post by choprboy » Sat Apr 02, 2016 9:45 pm
The Griffin GF800 appears to be rebadged, probably Rational Precision Instruments WE6800 (which in fact might be made by a completely different subcontractor, definitely not Sino I would guess though). Try this for a manual, surprisingly good translation compared to the Sino rebrands.
http://www.atrump.com/upload/downloads/ ... 405521.pdf
Post by SteveHGraham » Sun Apr 03, 2016 2:36 pm
I can't thank you enough. I looked all over the web.
choprboy
Post by choprboy » Sun Apr 03, 2016 5:46 pm
Eh, only took me a few minutes to find. I had previously looked at quite a few different models when replacing my Sino rebadge. It also helps to have the neural implant directly from Google; though it does come with inopportune nose bleeds, excruciating headaches, and a weird propensity to sing show tunes...
Post by SteveHGraham » Sun Apr 03, 2016 6:35 pm
I checked "Griffin," "DRO," "DRO Griffin GF800 manual," "DRO Griffin GF 800 manual," and every possible search involving Lih Rurng instead of Griffin. I replaced "DRO" with "digital readout." I put "PDF" in. I took it out. I rooted through the Lih Rurng website. I tried the searches with no brand name at all. Nothing.
I was not happy to see how many products there are with "GF800" in the name.
choprboy
Post by choprboy » Sun Apr 03, 2016 7:34 pm
Hehe... yeah, so close yet there isn;t a lot of correctly matching stuff out there with a few similar but different products that take the search in the wrong direction (i.e Griffin linear scales for DROs-> GF800 weighing scale). I went thru a few iterations and then "Griffin GF800 dro" gave me a manual (to the WE6800) in the second link. The manual had a matching "1/2 axis" display so I figured I was on the right track.
From there, a bunch of searching around Lih Rurng that was fruitless. An image search finally got me 1 small picture of the GF800 that seemed to match the manual and looked familiar. Then a bunch of looking closer at other rebadged Rational Precision Instrument DROs and I figured I had the original source.
fmitrade
Post by fmitrade » Thu Feb 21, 2019 2:30 pm
I need help on getting a copy of the manual for the Griffin DRO GF 800 control. Could someone help me out please?
