How Thick is a 1/2" Bolt (Used to Secure Grant's Tomb)
- SteveHGraham
Re: How Thick is a 1/2" Bolt (Used to Secure Grant's Tomb)
I don't know, but I imagine the soy sauce will have lead and melamine in it.
- SteveHGraham
Muchos gracias, Bill, but I have to buy the bolt anyway. Along with anything else that grabs my attention and jumps into my cart.warmstrong1955 wrote:
I've got bolt bins with 1/2"-13 x 1" to 4".
Want me to measure some?
They will measure to the numbers I posted already...
Bill
- warmstrong1955
Steve,
I scanned this for ya out of my common & notso common hardware book.
Note the diameter of the stock used to create rolled threads compared to cut threads.
If you don't have a Machinery's Handbook, Capscrews attached.
Bill
Bill
- SteveHGraham
Thanks, Bill. I do have Machinery's Handbook, but I didn't feel like fighting 9,000 pages of fine print looking for an obscure answer. I didn't even know what "pitch diameter" was.
I got my bolt, and the joke is on me. First of all, Home Depot doesn't carry 4" 1/2-13 bolts that aren't threaded all the way to the cap, and on top of that, the OD is about 0.495", which suggests to me that I will have to do two passes with a 1/2" mill to get a slot big enough for comfort.
In Grants tomb at least the bolt diameter will be twice the radius, unless it isn't perfectly round then all bets are off.
Jack.
Jack.
- liveaboard
I've had those problems too; basically, when trying to use a bolt as a pin that should fit a hole accurately.
The trick is; FIRST, obtain the bolt, then cut the hole.
Or; make the pin/bolt yourself.
