Setting up a "Precise Super 65" spindle grinder
Steve S
Post by Steve S »
My lathe chuck being at 0.006" run out started me down the path of putting together an I.D. grinding set up . I have an O.D. grinder already and decided that I wanted a dedicated I.D. unit . I picked up the Super 65 at a decent price , replaced the power cord , brushes and air filter looked good .
I soon relized that 45,000 rpms is way over what the i.d. stones would handle ( learned by research , didn't actually gernade one ) . More down the path , I found a correct speed control unit for the 65 . That is a rather salty price tag . Now I also see many of the photos show a type of chuck for 1/8" or 1/4" mounted stone or cutter bits . Can someone inlighten me on these spindle grinders . I'm wondering if I bought an apple when I should have gotten an orange ... I doing the math , I'm finding I can buy a new chuck for price I'm going to have in the tooling to atempt restoring by old chuck .
Steve S
Re: Setting up a "Precise Super 65" spindle grinder
Post by John Hasler »
"AC-DC" on the nameplate indicates that it is a series motor. A speed control should be quite straightforward. Does it have a tach?
Steve S
Post by Steve S »
No tachometer , will have to add that to the required component . The speed control is specific to the Super 65 .
Steve S
Post by Steve S »
stevec
Post by stevec »
Steve S wrote: The speed control is specific to the Super 65 .
I doubt the "speed control" is that "specific", I suspect it is no more than a variable transformer, but that's water under the "spent money bridge" now.
I'm also surprised that a smaller dia. stone would require a slower speed than a larger dia. "external" grinding stone.
I'll be following this subject with interest.
That's just a variac. A triac speed control would work as well. You've got yourself a nice variac, though.
stevec wrote:I'm also surprised that a smaller dia. stone would require a slower speed than a larger dia. "external" grinding stone.
That makes no sense. How a wheel (not stone) is applied makes no difference. Rule of thumb for vitrified bonded grinding wheels, regardless of diameter, is to operate at about 6,000 sfpm. Running faster offers the opportunity for the wheel to explode, and yields performance as if the wheel is harder than its rating. Operating slower than recommended speed results in a wheel that behaves as if it is softer than its rating, and won't perform to satisfaction.
Without speed control, the largest wheel that could be safely used with this tool is slightly larger than ½" (9/16" breaks the rule).
Steve S
Post by Steve S »
Harold ,
sfpm : surface feet per minute ?
Post by GlennW »
yes
Steve S
Post by Steve S »
I wanted to "Thank" everyone so far for their input .
Brings us up to collets . Is there a source for a 1/4" collet head ?
The spindle's output :
It's a 1/4" - 28 tpi shaft , 3/8" long . RH threads .
Which goes to a 1/2" dia. 1/4" long shoulder .
Ends with the 3/4" dia shaft housing .
Steve S
Post by Steve S »
Adapting a new one over to the 65 .
1/4" collet
Which brings us to tachometers . Contact or Non-Contact for figuring the surface feet per minute or rpm if the bit is so rated .
John Evans
Post by John Evans »
Non -contact have both ,the non- contact is much better.
www.chaski.com
