Hofmann indexer?
Hofmann indexer?
In the process of digging thru my dad's stuff, I cam across this.
It has the name Hofmann on it, and it looks like a 5C or some other collet in it.
My guess is that it is some kind of indexer, but I can't figure out how it works.
Anyone ever seen one of these?
Re: Hofmann indexer?
Actually, the collet isn't 5C. It's quite a bit larger and it comes in from the top, with the large plate on top being the closer.
I've attached a picture with dimensions.
Anyone recognize this? Steve
I did a quick check on Google, it's a work holder.
They're still in business ( Hofman ) and this is one -
https://www.hhw.de/en/Shop/Clamping%20e ... th_3-42_mm
Thanks. Sent them an email with pictures. We'll see what information they have.jcfx wrote:I did a quick check on Google, it's a work holder.
It may be an indexer of some sort, looking closer at your pics there is a scale engrraved on
I don't see where indexing plates would go.
I got it to work - there was a setscrew underneath that needed to be loosened. Not sure what that screw does.
Anyway, there is a circular segment that slides in a track and has a lock. You set the degrees on that and lock it in place. When you move the lever one way, it ratchets, when you move the other, it rotates until it hits the segment.
That Hofmann is looking like a really neat indexer. I thought the swing arm had some sort of ratchet but I didn't understand how it worked until your last pic. At first I thought the right side knob lever was to lock the table but there is that threaded hole in front. I think you should be able to adjust one semicircle to allow a set "arc" of degrees between the swing and then lock it, without lifting the unit. Pretty slick.
I've seen collets which "look" like those on Ebay. I think they are used with B&S screw machines. They used to be very inexpensive.
That lever IS the table lock. Once you move the arm to rotate the set arc, you lock the table before performing any operations.spro wrote:At first I thought the right side knob lever was to lock the table but there is that threaded hole in front.
The whole top of the thing is actually the locking ring.
It's an interesting tool, I suppose that the segments you mention are like detents so theSteveM wrote: When you move the lever one way, it ratchets, when you move the other, it rotates until it hits the segment.
graduated ring hits on every mark ?
When I said "segment", I was referring to the semicircular arc (it's 120 degrees and sits in on the left side in a channel). It just hits up against the end of the segment, which acts as a stop.jcfx wrote:It's an interesting tool, I suppose that the segments you mention are like detents so the
The arrows in the attached pic show the ends of the segment and the lock. Steve
I found out from the manufacturer that it takes a 455E collet.
Yea, I've never heard of them either, and the manufacturer stopped producing them 25 years ago.
A google search doesn't even show up a picture of one.
The top ring that holds the collet in screws off and is threaded 110mmx2.
There are four bolt holes in the top that are 8mmx1.25 thread.
My guess is that you could mount a chuck or face plate to the top and have a nice indexer. That piece could either be threaded or simply bolt to the top with some socket head cap screws.
You could make a fixture with a 5/8" spigot on it and mount it in the collet, or grind the collet out to a larger size to hold something bigger.
It is very heavy and won't fit in a flat-rate box.
If anyone locally is interested in it, make me an offer and get it off my workbench.
