Tilt Table
Tilt Table
Anybody know who made this tilt table?
Picked this up a a local auction house. I was previewing items for a upcoming auction and in the middle of the floor were two pallets with some "junk" on them they were throwing out. The guy in charge told me if I wanted anything on the pallets to take it. I spotted this tilt table and verified it was free to take. He even carried it out to the car for me. There is no badge on it, only M-1097 cast into the body. The top and bottom plates look to be added onto the body. The top plate measures 8"X10" and the entire thing is 12" high. It has a scale on one side of the casting and it tilts 90º either direction. It tilts by loosening 4 nuts and moving manually to the desired angle. I already have a smaller tilt table but couldn't pass this up.
Jack.
Jack.
Re: Tilt Table
Our friends here will ask "Where's the picture ?" and rightfully so. It does help with identification.
Re: Tilt Table
Someone in China?
Re: Tilt Table
OOOOPS. Here they are. Old age setting in.
Will have to try another method. I keep getting this message when I try to upload, "The upload was rejected because the uploaded file was identified as a possible attack vector." Anyone know what this means?
Jack.
Jack.
Re: Tilt Table
How are the pictures saved? Not all types of files are permitted on the board, for security reasons.
Re: Tilt Table
My camera saves them as .jpg. I will see if I can change that on my camera but I believe I have uploaded .jpg images before. Also the files are only 160k so that should not be the problem. I suspect that the problem lies in the fact that my computer no longer will recognize my camera card so I downloaded the pics to my wifes' computer then Emailed them to mine. I will next download the pics to a CD to transfer them to my computer. In any case pics will be coming.
Jack.
Jack.
Re: Tilt Table
No idea why it would reject jpg images, it shouldn't as long as they conform to the resolution limits.
I would suggest to upload them to a free file share (Google provides one example). Once you get it uploaded to the share of your choice, it should provide some means of sharing a link. Whether URL or embedded image thumbnail, that allows folks to get higher resolution images and avoids lots of potential problems (particularly when wanting/needing high res images). Then you can also share them on other forums, email, whatever. There is really no reason that transferring on CD should be required, but a simpler/faster choice along those lines would be something like a USB flash drive (if you have access to one).
Re: Tilt Table
Lets try this.
Finally. Can maybe get bigger pics if need,wanted. - Attachments
- SSC_0834.JPG (72.77 KiB) Viewed 3504 times
Re: Tilt Table
That appears to just be a thumbnail, and doesn't show much detail at all, though enough to get the general gist. Unless things have changed, this site should support up to 800x600 images as attachments, and you can provide full high res images on the hosting sites I mentioned. The hosting sites usually provide some auto-scale functions as well to help support lower res users without blowing out/off the screen. It's a really good solution wherever you post, and not that hard to figure out. And you only have to figure it out once, not on every site, some of which don't support attachments at all.
Re: Tilt Table
Thanks russ. Call me a worry wart but I just don't trust these hosting sites. Maybe it's just the owners of the sites I don't trust. I used to have Photo Shop, actually still do but it won't work on Mac OSX. I could do most everything with that including changing the format. I can still run it on my old computer but the monitor quit working.
Jack.
Jack.
Re: Tilt Table
It does look like a main casting of a dividing head welded to larger foot and table plates. It should be quite accurate by the degree settings when the surfaces are trued. The casting looks like L-W Chuck Co. Plenty mounting holes on that thing.
