I have a 1/2 hp washing machine motor that I want to use to build a drum sander but am unsure how it should be wired. The cover plate is missing and there are no leads - only three lugs. Here are the specs for the motor:
CANADIAN GENERAL ELECTRIC COMPANY LIMITED
TORONTO CANADA
APPLIANCE MOTOR
MODEL ME
4J620AX2
TYPE KH
FRAME 44
H.P. 1/2
RPM 1725/1140
VOLTS 115
CY 60 PH-1
AMPS 7.9/7.2
130C INSUL
INGLIS
508569
THERMAL PROTECTION
27084-14
I have attached, hopefully, a picture of the connection lugs. There are letters (C,W, H and BU) near each of the lugs which can be seen in the picture but mean nothing to me. There are only three connection lugs.
The image identifies the lugs and the ohm readings between them. I also identified which combinations of lugs will run the motor using a 120 volt line. The problem is that three of the combinations will run the motor and I have no idea which is correct. Neither can I see any difference in speed between any of the arrangements. I only need the motor to run at the higher speed.
I have found nothing online related to this motor using the information provided.
Any thoughts would be greatly appreciated.
wiring for single hase two-speed motor
Re: wiring for single hase two-speed motor
This has lingered too long. Many know but didn't look at this as a request. Post in general discussion and get it done. This is motor candy for some of the folks here.
There are a bunch of wiring diagrams available here:
http://www.usmotors.com/TechDocs/Connection-Diagrams
Seer if one of those matches your layout.
- warmstrong1955
Huh.....I didn't see this post....
Looks like a 2-speed swamp cooler motor.
I took a look at a couple, an Emerson, and a Dial, and are a touch different on the spacing of the terminals, but between the two, the lugs are the same.
Also, both the ones I have here, the lugs are labeled L, C, & H.
If these are the same as your GE, as far as wiring, by the letters on your pic, it would connect:
A = Low
B = Neutral
C = High
So....there's a maybe....(better late than never?)
A = Low
B = Neutral
C = High
