How stubborn are you?
- warmstrong1955
Re: How stubborn are you?
Yes indeed.
Who else spends thousands and thousands of dollars for machine tools, to make a new handle for their wife's crock pot lid?
That would be us!
That would be us!
Looks good. I should do that to my IH544. Unfortunately, I can't get the steering wheel off! (and the seal on the power steering mechanism leaks)warmstrong1955 wrote:I'm kinda partial to Cole Hersee rotary switches.....if you can't tell by the pic.
A complete rewire on a JCB thing....Before I cleaned up the new panel and installed some real labels.
I could cut it, but then I'd have to buy a new wheel and I'm too cheap to do that. Hmm. Maybe I could *make* one for only two or three times the cost of buying one...
- SteveHGraham
It's sad how true this is.
Another side to the coin: friends and relatives asking us to use our high-dollar tools to fix their worthless crap.
- warmstrong1955
Thanks John!John Hasler wrote: Looks good. I should do that to my IH544. Unfortunately, I can't get the steering wheel off! (and the seal on the power steering mechanism leaks)
And I hear ya....
Did you notice in that pic, how pretty the steering wheel is? Original was stuck....rusted & fused to the shaft... (Standard routine with underground mining equipment) It was stuck enough, to where the 2 holes in it for the puller bolts stripped out when I was trying to pull it. I drilled & tapped them out to the next larger size, and they stripped out as well. Ended up slicing it on one side of the hub with a cutoff saw.
I thought about making a new wheel....but with a weird metric spline, I hate to imagine what that broach would have cost...
Oh well.....
I had to design it with a bunch of stuff (electrically) that normal mortals don't need. Since we may have used the machine in Canada, it had to meet Ontario Brake Specs.
It was a vast improvement over what it was when I started though. The stuff I removed......
- warmstrong1955
I had to go to Youtube & watch part 2.SteveHGraham wrote:It's sad how true this is.
Thanks for that....Worth a dollar!
There was a saying...... "Use it up, wear it out, make it do, or do without!"
My parents were depression era folks. My Dad fixed all sorts of things like that, in his little shop, known by us kids & Mom, as the 'Acme Tool & Repair Company'. (Named after Wile E. Coyote.....Genius!)
Looks like normal repair stuff to me....
It's hereditary it turns out.....
"Leftovers"? I hope you didn't throw it away: that looks like good stuff!
- SteveHGraham
I can't count the times I've started to order materials or tools to fix something and then realized the thing I was fixing was basically worthless. It doesn't always stop me.warmstrong1955 wrote:I had to go to Youtube & watch part 2.
Crock pot handles? Thought I was the only one who made them.
- warmstrong1955
I'm part hoarder..... So....not a chance.John Hasler wrote:"Leftovers"? I hope you didn't throw it away: that looks like good stuff!
Unless it was absolutely worthless, like the crispy-hard hydraulic hoses & melted wires. I either still have it, or it's been 're-purposed', or, a lot of the stuff went back to the mine, for spares for the other machines like it. We had three at the time.
- warmstrong1955
Bet there's quite a list of crock pot handle makers here!mcostello wrote:Crock pot handles? Thought I was the only one who made them.
Bill, very nice work on that control panel! I'm reworking a Kubota tractor dash that had a minor fire in the cluster. Other than ruined wiring and ribbon circuit (along with a few relays) the only damage is some discoloration. The key switch is fine, but I had looked into doing something like you did to replace some of the switches and realys (lights mainly). I know the economics are a bit different working on the mine equipment where reliability is money, but if I'm not mistaken that's at least $200 worth of switches alone, unless you've got a better source (probably) that I do. So I punted and built a new copper wire harness (mostly idiot lights) with automotive push-twist turn marker light (small blade) sockets/bulbs, and the current plan is to go with inexpensive low amp switches with a small bank of relays to control everything else (including improved task lighting). Going to try to finish that up once the heat comes in full force and I retreat to the AC. For now trying to get the outside work done before then.
Sorry for the side trip.
As others have said, I too am both an glutton for impractical work and a hoarder. But it's not so much stubbornness as impatience combined with having grown up dirt poor (literally on a dirt road in a single wide trailer) so that NOTHING that can be salvaged goes in the trash. So throwing something out to replace it, or waiting till I can make a trip or get a shipment on something I just broke trying to use it, that's just not happening if I can help it...
I have owned several Kubota tractors (none anymore though), all worked good, lasted a long time. Your dealer apparently is very tight fisted, mine gave me lots of keys. I had one or two given to me that were fancy, with a polished logo on the handle part, some sort of promotional thing. The rest were flat, plain ones.Harold_V wrote: Yeah, like you, I'm pretty damned stubborn. Not about to pay an unreasonable fee for something that is mass produced.
I would have balked at six bucks each for those keys.
- Wes
