hyd cyl piston
Randall Va
hyd cyl piston
Post by Randall Va » Fri May 26, 2017 7:50 pm
My buddy has a 3"id hyd cyl and wants to make a piston for it,anyone know how much clearance it should have ane how deep groves for o rings? also is there a source that tells o ring grove depth? Thanks
www.chaski.com
johnfreese
Re: hyd cyl piston
Post by johnfreese » Fri May 26, 2017 7:59 pm
That is somewhat dependent on the seals. Check the Parker Seals handbook for suggested clearances.
Randall Va
Re: hyd cyl piston
Post by Randall Va » Sat May 27, 2017 4:49 pm
www.chaski.com
