Help Me Understand my Boring Head Arbor
ctwo
Re: Help Me Understand my Boring Head Arbor
Post by ctwo »
SteveHGraham wrote:Interesting sidenote: I got a good suggestion for removing the arbor. You mill the flange down to nothing and then try to turn the arbor. The flange pressure helps keep the arbor stuck in place.
I considered this when I was thinking about the problem, but since no one else had suggested it at that time, I decided not to take a chance.
First reply:
GlennW wrote:If you prefer to make a new arbor you can always just machine the old one off of the boring head if you can't get it to unscrew.
But you got it done the harder easy way. :twisted:
SteveHGraham
Post by SteveHGraham »
If you take a look, Glenn wasn't talking about unscrewing it. He was talking about the brute force/many chips way, which I already knew.
earlgo
Post by earlgo »
From the gun-smithing side of things:
The only way that an Enfield barrel can be removed (without disgusting body noises) is to set the barreled action up in the lathe and cut a deep slot just in front of the receiver ring with a cutoff tool. This relieves the compressive stresses and allows the barrel to be unscrewed with not much effort. This we were taught at the Colorado School of trades in 1970 when folks were still sporterizing Enfields. Every other military barrel came out by using the barrel vise and action wrench. The instructors had tried the same procedure with the Enfields and said it was just not possible. They said that the barrels were screwed in by machine at the factory.
Soooo, transferring that info, what the fellows say about turning off the flange first may be the way to go.
Good luck.
--earlgo
