Here is a hold down clamp I made using a door hinge costing less than $3. If you are interested in the build here is a link to the video
https://www.youtube.com/watch?v=0Xywab9tgcc
and here is a link to it being used
https://www.youtube.com/watch?v=0YuED-agIdE&t=17s
Surface grinder door hinge hold down clamp.
Re: Surface grinder door hinge hold down clamp.
I'm glad that I watched the video. Whole lot more than a hinge. Thanks!
Hi spro,
Thanks, did you watch Robin's video on the stones too?
I did. Very cool on both, and not something I would ever have considered.
Hi BadDog,
You can buy the stones for around $16 each and grind them up yourself. If you buy the stones they cost $500 a pair.
Hi Steve, watched both+ . When the stones are this precise and can be renewed, it does open another door.
