My Unfinished Projects List shot milk out its nose when it read that.spro wrote:You don't lack momentum.
Milling round stock to square, on center
Re: Milling round stock to square, on center
I flipped a coin, the colletless collet blocks won.
I checked height of the bar at 8 points on the surface plate, it's got a max variation of +/-.0002. Blocks were made on the same poor li'l drill press that will make the square drive shaft so it's capable of good numbers... as long as the Z isn't messed with between cuts."Never trust a man who puts a witty quote in his sig line." -Mark Twain
ccfl:
I totally understand the money issue.
Congrats on choosing to make this part, and thanks for sharing your process with us.
