It's as long as it is because it also engages the taper attachment.
Later models (or models based upon a similar concept) used a two piece crossfeed rod - that enabled the taper attachment to be easily removed.
Measuring (probable) Acme TPI
- neanderman
Re: Measuring (probable) Acme TPI
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Great Ed. No internal splines. If you tell me that you want to reproduce the thread to fit a worn nut, no you didn't.. An accurate thread at the cross slide is a precise register. I wouldn't be surprised if the cross nut has some adjustment to it. This can work very well without a person cutting Acme threads along the length.
- neanderman
The nut doesn't have any adjustment, sad to say. It is also pretty worm and would be replaced at the same time.
Ed
Atlas 618
Atlas 618
- neanderman
I would certainly consider that option.
Ed
Atlas 618
Atlas 618
