What is this toolholder?
SteveM
Post by SteveM »
Found this toolholder in my dad's shop:
It has a square hole at the end for a 1/4" tool bit and a screw to hold that in.
The piece that is inset into a groove below the hole is held in place with a pin, but I can't move the piece, so it looks like it's not a hinge pin.
Any idea what this is?
I was thinking that it was some form of spring tool.
BadDog
Re: What is this toolholder?
Post by BadDog »
Looks like it's a spring tool for an old lantern tool post. The tongue-n-groove below would help provide lateral stability, but still allow the tool to move down and away should it encounter problems.
SteveM
Post by SteveM »
BadDog wrote: Wed Jan 31, 2018 12:27 pm Looks like it's a spring tool for an old lantern tool post. The tongue-n-groove below would help provide lateral stability, but still allow the tool to move down and away should it encounter problems.
OK, that makes sense.
Thanks
Mr Ron
Post by Mr Ron »
It does look like a spring something or other, but how would they manufacture something like that from one piece?
Mr.Ron from South Mississippi
mcostello
Post by mcostello »
Heat to red, beat to move, and finish.
tornitore45
Post by tornitore45 »
The picture is not clear but it looks like the tongue is held in a mortise in the bottom left. In such case the part can be forged and the tenon force fit after.
Mauro Gaetano
in Austin TX
SteveM
Post by SteveM »
If you are referring to the cross bar under the big hole, it is pinned in place.
You can just see the outline of the pin in the second picture, just to the left of the split.
Mr Ron
Post by Mr Ron »
SteveM wrote: Thu Feb 01, 2018 4:27 pm If you are referring to the cross bar under the big hole, it is pinned in place.
I blew it up and now I can see how it was made. It looks like there are 2 pins holding the crossbar in place; the one you pointed out and another to it's left in the curved area. It could have been machined and not require any heating and forging. If it were forged, how would the hole survive not being distorted? I still think it is a spring tool holder. The crossbar is just to prevent the tool from twisting.
wlw-19958
Post by wlw-19958 »
Hi There,
It looks to me that the tool holder was first forged
(which included the bend/angle) and then the 'hole'
drilled/bored and the mortise cut and tenon inserted.
Good Luck!
-Blue Chips-
Webb
spro
Post by spro »
Yes. Some earlier ones were merely a split forged and finished. Then they had a heavy "clock spring" and a pin (to alighn). This is a gooseneck variation with the tongue to serve that purpose and since it was made for 1/4" tools, they already knew the relative pressure and spring.
