Self centering vise
stephenc
Self centering vise
Post by stephenc » Sat Feb 17, 2018 5:31 pm
I haven't bought any tools for awhile and it's time .
So I have it in mind to buy a self centering vise , there's no way I can afford a nice Kurt or even one of the nicer made Taiwan made vices .
But I can afford one like the grizzly h7576. It's a 4 inch vice .
Size wise it suits my needs and it fits nicely in my budget @ $218 shipped .
Might anyone here have experience with this or a similar Chinese vice , I am by no means expecting perfection but I also don't want to waste my hard saved cash on junk
My intended purpose is to use it to make bullet molds to help my my other addiction.
GlennW
Re: Self centering vise
Post by GlennW » Sat Feb 17, 2018 10:31 pm
I can't really imagine any advantage to a self centering vise in a mill.
I always work from one corner of the fixed jaw on a milling vise as the dials are zero'ed there and it remains constant. By doing that, you are always working in a positive direction from zero.
Being zero'ed on a center point between two movable jaws makes you work in two quadrants rather than just one, so you now have positive and negative movements from zero.
stephenc
Post by stephenc » Sat Feb 17, 2018 10:55 pm
Bullet molds are made with a cherry on a mill ... unless you have a very precise cnc mill.
You fixture the mold halves to the vice jaws and close them on the cherry to cut the mold cavity
spro
Post by spro » Sun Feb 18, 2018 6:47 am
I don't understand things which I haven't had direct involvement. I try and fail but it is interesting to know why these vises are selling fast. When stephenc mentions "cherry on a mill" , I think that is short for a "Cherry head" which is a certain unit. Volstro and others made similar attachments. Once the core or any core is centered, the head or attachment swings an adjustable spinning milling tool. The head itself is not spinning but has control over the end mill or shaped spinning ball end, to mill inside or outside to a variable....
why am I even here ? You can see this in operation now.
GlennW
Post by GlennW » Sun Feb 18, 2018 7:05 am
A bit of Googling, ad now I see what you are doing...
stephenc
Post by stephenc » Sun Feb 18, 2018 1:09 pm
Spro
Think of a mold cherry as a form tool , in this case it is the size and shape of a bullet and it will have flutes like an endmill so it can cut .
There are a few ways to make bullet molds , you can use a lathe and bore the cavity
But it is a very precise and tedious operation , and of course you can also use a cnc mill .
The issue with lathe boring or using a cnc mill ( if you have one ) is that both usually require more then one cutting tool for bullet designs with a pointed or round nose .
I've gone the lathe boring route a couple times , it is tedious and one little oops moment will ruin hours of work .
My one semi success took about 15 hours of effort and still wasnt what i wanted it to be .
wlw-19958
Post by wlw-19958 » Sun Feb 18, 2018 1:59 pm
Hi There,
The term "cherry" comes from the bygone days
of muzzle loaders and the bullet commonly used
in them. Back then, the round ball bullet was
the norm and the cutter was spherical with a
stem that was held in the mill (or hand powered
drill in more primitive times). This made the cutter
resemble a cherry fruit.
Good Luck!
-Blue Chips-
Webb
stephenc
Post by stephenc » Mon Feb 19, 2018 3:40 pm
So not really expecting much I went ahead and ordered a vise from grizzly.
It's $218 with shipping, so if it doesn't suit my needs for making molds I'm not out a fortune. If nothing else it'll make a pretty dang good drill press vise.
I have a couple ideas on a jaw fixture to hold the mold halves. Once I have it in hand, I'll solicit for some opinions and ideas.
ctwo
Post by ctwo » Tue Feb 20, 2018 9:39 pm
Wow, another tool and a practical use for it. I could see something like that being helpful on a drill press.
stephenc
Post by stephenc » Thu Feb 22, 2018 3:23 pm
let's not get carried away and say anything I do is practical , more often then not it isn't .
Anyhoo ... one thing I can say about grizzly is that they don't waste anytime shipping .
Order on Sunday and it's here on Thursday .
First impressions. .. it looks fairly well made , for what it cost .
Fit and finish is better then expected , I'll have to get it bolted down and see what an indicator says on that subject .
What with the next step up in quality costing 4-6 times the money I'll be pretty easy to please .
