Slitting saw
Re: Slitting saw
I read everything you write.
Re: Slitting saw
Earlgo
Cut off wheel .... great idea , worked perfectly .
Re: Slitting saw
Glad to hear it.
That technique always worked for me when it was needed.
--earlgo
--earlgo
Re: Slitting saw
Again I wish I had a surface grinder. I need a .050" slit 1.5" into the end of a 1"x1"x2.5" part. I'm looking at making it in two pieces and then brazing them.
Re: Slitting saw
Shaper?
Sent from my iPhone using Tapatalk Pro
Re: Slitting saw
I've tried making slits with the shaper. My little Logan 8. Is fairly rigid for a small shaper but if you make one false move that thin little tool breaks real easy .
Re: Slitting saw
One of my old machinist books briefly touches on slitting saws with some information I've not seen anywhere else but it seems to work in practice. They recommend for deep slots to get a cut line established first. Make a cut .050" or so first then each further cut no deeper than the tooth gullets as some else mentioned. They also state the recommended sfpm should be reduced to 50% - 60% of what normal hss cutting tools are listed at for the same material. So 50-60 rpm for a 4" diameter slitting saw in mild steel. My mill in back gear with a vfd will go that slow but many of the smaller mills just don't have enough torque left at those slow speeds. They don't detail exactly why, but my guesses are the first cut is light enough the blade shouldn't wander and that first straight slot helps to guide the next cut a bit. The slower than recommended surface speed is likely because so much of the tool is buried in the cut so heat is more of an issue?
