That DC path actually originates on the Nelson River in northern Manitoba! It runs to a station just outside of Winnipeg and then carries on to Forbes in N.D. (Being retired from Manitoba Hydro, our responsibility ended at Forbes LOL!)
unique water pump
Re: unique water pump
But they got rid of the ignitrons! Those were sooo cool.
https://en.wikipedia.org/wiki/High-volt ... lam_MB.jpg
Thanks for that info. It's interesting that the path would take it to Forbes, ND. There are much shorter paths it could have taken. Was the line split there or was that just the only path that particular line could take?
It all comes down to politics and economy and the HVDC line avoided the more populated and expensive land.
This post was in violation of board policy, and has been deleted, as no cites were presented.
Note that it has been copied and saved, and can be reinstated if cites are provided. Otherwise, it can safely be concluded that it is nothing short of nonsense.
Be advised----misinformation is not permitted on this board.
- liveaboard
Well then, you'd best get to it. I wish you the best of luck with your endeavors.
Troll. Agree with Bill.
SteveR
SteveR
12x36 Enco Lathe, 9x42 Bridgeport, SMAW, O/A, Miller MIG w/gas, plasma
Not enough measuring tools...
1.5" Allen Models Consolidation on air.
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
1" FEF in progress
No, not a troll. Trolls start arguments and/or post outrageous assertions so that they can then sit back and laugh at the response. People with these sorts of obsessions can behave quite rationally (as reubenT does) as long as none of their triggers get hit.
Reality is a hard mistress.
A man of foolish pursuits, '91 BusyBee DF1224g lathe,'01 Advance RF-45 mill/drill,'68 Delta Toolmaker surface grinder,Miller250 mig,'83 8" Baldor grinder, plus sawdustmakers
As I stated in the edited post, if cites to verify the claims made are not provided, that post is going to be deleted. It is highly controversial and filled with claims that tend to be impossible to verify, and are highly unlikely to be true. Said another way, they're misinformation---and that's not what this board is for, nor is it here so less than flattering comments can be rendered towards the readership.
OK, no more on the theories. I guess I just know too much about stuff I'm not supposed to know about, I should learn to not talk about it because no one wants to hear. Can I report actual physical and electrical measurements when the device is operational and tested? or is that forbidden as well? It's just a different kind of water pump, I think it is an interesting concept that needs to be tried and detailed measurements made on it. And I will have to make my own gas/air valves since I'm not going to buy them for hundreds of dollars apiece.
I wish you luck and good fortune with this unique learning experience.
