Indexable insert holding system ?
jcfx
Post by jcfx »
I'm looking to get 3/8" shank indexable boring bar for my lathe, I've noticed that most of them use a torx screw thru the center of the insert to
hold it to the shank, some have a finger clamp system to do the same. Which one would be the best in terms of rigidity ?
John Evans
Re: Indexable insert holding system ?
Post by John Evans »
If you are buying a 3/8 shank bar to do smaller holes I think you will find the top clamp style will have a fair bit larger minimum bore size . Which means you might as well start with a larger bar.
www.chaski.com
jcfx
Post by jcfx »
I've anticipated that a top clamp style would make the minimum bore size larger, what I'm more concerned about is rigidity of the insert to the shank.
John Evans
At last count I have 20+ insert style boring bars and as I recall none under 1/2 have clamps. I will say that one bar I have with screw only I have to keep a eye on the tightness of the screw,don't seen to have problem with any of the others. It is important to use the correct insert/screw set as you can use the wrong combination and still put things together. I have to watch that issue as I have a real dog's lunch of bars and insert types.
www.chaski.com
RMinMN
Post by RMinMN »
jcfx wrote: Fri Sep 21, 2018 4:20 pm I'm looking to get 3/8" shank indexable boring bar for my lathe, I've noticed that most of them use a torx screw thru the center of the insert to
The rigidity is not from the holding method but the supporting steel right under the tip of the insert. You're overthinking this.
Richard_W
Post by Richard_W »
The torx screw is the way to go. I would dearly love to switch all my TPG/TPU insert boring bars to that. On such a small bar you should go to a solid carbide boring bar for best results. I have a 1/4" solid carbide boring bar and it works really well. I have 3/8, 1/2, 5/8, 3/4 and 1" diameter boring bars that take the torx screw. (CCMT series inserts) It allows for better chip removal because of the less interference of a clamp and with a screw system.
Edit The CCMT are steel boring bars with the addition of a 1/2" and 1" heavy metal boring bars.
