I have a smallish shed, 5m x5m so space is limited. halfway along either side wall is a 6" post that juts out the same amount, this precludes largish machines being placed in front. When last in Aldi I spotted a small bench drill which I though would do well next to the pedestal so I mounted the bench drill on a bracket I made that clamps around the pole. I also included a couple of stickouts on which to mount two drill sets.
While I was at it I made up a similar clamp for the other post and mounted the belt grinder I made a while back.
Both work quite well, free up bench space and use space not normally used.
Belt grinder and bench drill post mounts.
Re: Belt grinder and bench drill post mounts.
Now that's using your noodle! Any space gained is a real winner.
Pete
Pete
Just tryin'
- tornitore45
Now you no longer own a drill press, you have an old fashion Post Drill
Mauro Gaetano
in Austin TX
in Austin TX
Must be an Aussie with those safety boots. Out of curiosity does the structure transmit/amplify sound from the machines? Drumming or humming noises?
Pete
Pete
- SteveHGraham
Nice work. Saving floor space is always good.
You could say it hurt a little.
I am glad I started wearing safety toes last year. Too bad I don't wear them when I get the mail.
A couple of days ago, I received a box containing a Garland rawhide hammer (metal with rawhide faces). The box fell four feet off a counter and landed on my left little toe. The only thing between me and the hammer's head was 1/8" of cardboard. I was barefoot, and I was standing on a hardwood floor.Must be an Aussie with those safety boots.
I've been wearing the safety Croc, or similar, for 50+ years and I still have all my toes, all 13 of them! No noise reverberation from either, a bench grinder would be different I'd bet.
Bloody oath mate, I'm Aussie and flat out like a lizard drinking,
Fine in many ways beyond describing now. That clamp says a lot too. Do this right and it ain't falling down because the machinery supports it. Screw noise and chatter, that can be insulated later. Thanks for revealing a part of really nice shop.
