After all these years I have finally figured out how to get around the fact that the tap guide always has the wrong end out.
I bought a second one. Now I can choose the one with the proper end showing. No more hunting for the screw or spring under the bench or in the chip tray. HAH!
--earlgo
Tap guides
Tap guides
Re: Tap guides
Good idea Earl, when I fially get around to building one I'll now need to make two. So you've just doubled my work.
