Layout dye
Mr Ron
Layout dye
Post by Mr Ron » Mon Oct 15, 2018 2:54 pm
As far as I know, there are two layout dyes available; red and blue. Is one color better than the other, or is it just a matter of preference?
Mr.Ron from South Mississippi
tornitore45
Re: Layout dye
Post by tornitore45 » Mon Oct 15, 2018 2:57 pm
I prefer blue, it seems to give a better contrast.
I can see the use of two colors if you have mirror image parts and want a reminder to place the feature in the right place.
mcostello
Re: Layout dye
Post by mcostello » Mon Oct 15, 2018 8:53 pm
I have a can of red that I have had since 1982, almost used up. It seems to last to the end, not like the blue that seems to separate out. Blue users have any comments?
Re: Layout dye
Post by spro » Mon Oct 15, 2018 9:34 pm
I just use the blue in smaller tubes. It does separate over time or temperature extremes. I try to knead it, remix it. It is tempting to remove the cap but that isn't air in there. It is a chemical component of the mixture which vaporized.
Richard_W
Re: Layout dye
Post by Richard_W » Mon Oct 15, 2018 11:00 pm
I did have a can of white at one time. I find that different colors work well for different materials and lighting.
BigDumbDinosaur
Re: Layout dye
Post by BigDumbDinosaur » Tue Oct 16, 2018 12:40 am
Due to a vision problem called tritanomaly, I can't see pure blue—it appears to be nearly black. Hence blue layout dye actually works well for me. :D
As was noted, red can be useful for identifying mirror images and other specific layout features. To me at least, red doesn't contrast as well with scribe marks, so I seldom use it.
ctwo
Re: Layout dye
Post by ctwo » Tue Oct 16, 2018 2:31 am
I wonder if shaking the bottle ever so often helps the blue not separate... If it does separate, I won't buy it again, and I'll be back asking if IPA or acetone will redissolve it.
Re: Layout dye
Post by Harold_V » Tue Oct 16, 2018 3:15 am
Knead it?
Sounds more like Prussian blue than any layout dye I've seen. Prussian blue comes in a tube, but any layout dye I've ever encountered was in a container with a brush, or in a spray can. While what you described may work for layout, it's not really well suited, assuming I'm right.
Can you better describe what you have?
I've enjoyed the same experiences as have been reported (drying out). The Dykem blue I've had evaporates quite quickly. I don't use it much, but it's nice to have on hand for those strange occasions when I do a layout. It is readily restored to usefulness by adding a little acetone. When it's too concentrated it doesn't work well.
tornitore45
Re: Layout dye
Post by tornitore45 » Tue Oct 16, 2018 8:42 am
The can of blue bought some 8 years ago went "light" (meaning lost the opacity) after a couple of years, an experience reported by others.
Older blue formulations lasted indefinitely.
I have a felt capped "roll on" type of container of blue that is still good after 6 years.
Re: Layout dye
Post by SteveHGraham » Tue Oct 16, 2018 11:19 am
I started using blue Sharpies, and now I hate Dykem.
Mr Ron
Re: Layout dye
Post by Mr Ron » Tue Oct 16, 2018 11:47 am
I have been using Dykem blue and find it doesn't cover evenly and when dry, doesn't allow for a clean scribe. The blue seems to be thick in one place and too thin in others. The can is about 3 years old and I haven't shaken the can. I'm thinking it may be too thick, in which case, I will try adding some acetone.
I had a spray can of dykem red, but somehow, the can burst and spilled the red dye all over. I liked the convenience of using a spray over brush.
Has anyone else ever had a problem with spray cans leaking or exploding?
jcfx
Re: Layout dye
Post by jcfx » Tue Oct 16, 2018 1:13 pm
Dykem layout fluid ( the kind that dries ) comes in Blue, Red, Yellow and Black, I prefer the black since it gives me
a nice crisp contrast, more so than the blue.
