Great way to take up time...
curtis cutter
Post by curtis cutter » Sat Dec 15, 2018 4:36 pm
I found this very effective way to waste time. I took my microscope out to the shop and really looked at the cuttings edges on my tooling.
Need I say more. :)
Gregg
tornitore45
Re: Great way to take up time...
Post by tornitore45 » Sat Dec 15, 2018 5:53 pm
Yes
curtis cutter
Post by curtis cutter » Sat Dec 15, 2018 10:32 pm
Ha! It was very enlightening to examine some of the edges on tools I was using. I had some that were cheap foreign made carbide that appeared sharp but under the microscope were really quite rough and I am surprised they would even remove material.
I also looked at some that I had dressed with a CBN wheel and then finished with a diamond hand hone. Even with the finest stone I could still see marks under the microscope.
I am considering finishing with the hand stone in the direction that the chips would flow as opposed to honing 90 degrees to the direction of the chip flow. It is probably an insignificant thing but I found it interesting never the less.
Gregg
Conrad_R_Hoffman
Post by Conrad_R_Hoffman » Mon Dec 17, 2018 4:02 pm
Hey, wait until you start looking at small drill bits. I've seen some where the grind was backwards. Yes, the grinding and stoning should be perpendicular to the edge for the strongest edge. I also suggest people not use carbide paper and such to finish edges because they round the edge right where you need it free cutting. A good stone and remember that a single swipe at the wrong angle can take forever to correct.
Conrad
Post by Harold_V » Mon Dec 17, 2018 4:51 pm
I agree! 8)
There are those who still promote the use of a belt sander for sharpening cutting tools. That's a process I highly recommend AGAINST, for the precise reason you mentioned.
Doesn't matter how clever the operator may think he/she may be--it's the nature of the beast----anything less than a fully rigid surface has the potential to round cutting edges.
neanderman
Post by neanderman » Tue Dec 18, 2018 1:59 am
That was your first mistake...
Ed
Le Blond Dual Drive
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
curtis cutter
Post by curtis cutter » Tue Dec 18, 2018 9:42 am
:lol:
Gregg
mcostello
Post by mcostello » Tue Dec 18, 2018 10:15 pm
Next comes a cutter sharpening machine! :) :)
Conrad_R_Hoffman
Post by Conrad_R_Hoffman » Thu Dec 20, 2018 11:18 am
That may be the worst result of getting a surface grinder. It makes you realize how badly you need a proper tool and cutter grinder to go with it.
Conrad
earlgo
Post by earlgo » Fri Dec 21, 2018 2:26 pm
Ummm. CRH would you please explain why one couldn't use a surface grinder to sharpen tools with the proper fixturing. The toolmaker at a company I worked with used the Boyer Shultz for either operation, and observing him proved to me what could be done. One can do remarkable things with a 3 axis vise or sine plate and a bit of innovation.
--earlgo
Post by Harold_V » Fri Dec 21, 2018 5:19 pm
While it's true that a surface grinder can be used for sharpening cutters, they typically lack the locks and other features (like the ability to rotate the wheel head) that make a cutter grinder better suited to the task.
A cutter grinder that isn't well tooled is nothing more than an expensive pedestal grinder. It's the accessories that make them what they are.
