What is it?
Mr Ron
Re: What is it?
Post by Mr Ron » Tue Jan 01, 2019 12:53 pm
JackF wrote:
Mon Dec 31, 2018 8:01 pm
A friend of mine used to work for Alaska Copper in Seattle and they used their Duall? band saw to friction cut stainless steel. They used the back side of the saw blade at top speed. I was told it cut through like butter.
I don't think I would try that using a garden variety bandsaw with rubber tires. The hot blade would destroy the tires. I don't think a doall has rubber tires.
Mr.Ron from South Mississippi
Re: What is it?
Post by spro » Tue Jan 01, 2019 9:33 pm
This answers some questions. I bought a Boice Crane bandsaw decades ago and it had rims of some sort of material resembling brake lining. The machine had a two stage gearbox which I appreciated for lower speeds. The gearbox allowed much higher speeds than I would consider using for anything..
Re: What is it?
Post by Harold_V » Wed Jan 02, 2019 2:03 am
Yeah, they do have. Because they will operate with various blades widths, and because the teeth shouldn't make contact with a hard surface, they have a rubber liner inside the main wheels, which have a rim on each edge. The rubber is about 1/8" thick.
I can't address the purpose built friction saws, though, as I've never seen one.
rrnut-2
Re: What is it?
Post by rrnut-2 » Wed Jan 02, 2019 10:35 am
Our saws had rubber tires. The rubber was vulcanized onto a steel band. We cut the old one off and clamped, hammered and swore at putting the new tires on, I know that because I changed a few of them and it took 2 people to do the job. These tires were 5ft in diameter. They are still using these saws.
Jim B
rrnut-2
Re: What is it?
Post by rrnut-2 » Wed Jan 02, 2019 10:39 am
The guide wheels on these machines were steel, 3 on the top guide and 3 on the bottom guide, all 3.5" in diameter. Guide wheel ass'y on the top were hydraulically positioned to the operators choice. The blades had teeth facing the normal way for a bandsaw.
Jim B
