Mini-insert Cutoff Tool Question
gwrdriver
Post by gwrdriver » Tue Jan 22, 2019 3:48 pm
I inherited some tooling which included a Nikcole (#THE-7-1/2R) holder and cutoff insert and a test cut was brilliant, and badly needed tooling.
I have a toolpost block I'll dedicate for use with this but I'll need to shim the holder up to correct height.
So, what should correct height be for such an insert? One would assume spot-on lathe C/L, but I don't know much about inserts.
GWRdriver
Nashville TN
pete
Re: Mini-insert Cutoff Tool Question
Post by pete » Tue Jan 22, 2019 4:11 pm
Nikcole make great tooling Harry and I've got a couple of those mini cut off tools. Fwiw I set mine up at my lathes C/L and they seem to work just fine even on my little Emco C5 lathe. Your Harrison should do far better with them.
Post by NP317 » Tue Jan 22, 2019 8:38 pm
I always set them on turning center line.
Worked fine, all the time.
Excellent for slotting.
warmstrong1955
Post by warmstrong1955 » Tue Jan 22, 2019 8:51 pm
Yup, on center.
I've made many o-ring & snap ring grooves with mine.
gwrdriver
Post by gwrdriver » Tue Jan 22, 2019 11:18 pm
That's what I assumed, but you never know, so I thought I'd better ask.
Thanks for the confirmation.
GWRdriver
Nashville TN
SteveM
Post by SteveM » Wed Jan 23, 2019 1:09 pm
I got a pile of Thinbit toolholders and bits.
They come in HSS, C5 and C6 carbide, in different widths for grooving and threading.
I have used the threading bits, but not the grooving bits, but I suspect that when it comes time to cut a groove, these are going to come in VERY handy.
spro
Post by spro » Wed Jan 23, 2019 5:47 pm
I agree.
