What do you call this 'whattayacallit'?
Electrojim
Post by Electrojim » Wed Jan 23, 2019 7:14 pm
Am I going senile or have I overdosed on Metamucil? I could have sworn that, years ago at least, one could buy little steel tubes with a specific OD and an ID to accept popular size drills. These could be pressed into softer-metal or even wood 'templates' (for want of a better term), so when you drill through these tubes the holes would be in the right spot for making multiples of something. I've looked under 'drill sleeves' and 'drill guides' and find nothing. Am I nuts? (Don't answer that!) Thanks!
warmstrong1955
Re: What do you call this 'whattayacallit'?
Post by warmstrong1955 » Wed Jan 23, 2019 7:26 pm
They are still out there.
Drill bushings. I've bought many for manufacturing drilling fixtures, mostly from McMaster Carr.
https://www.mcmaster.com/standard-drill-bushings
You may still be nuts.....but hey....aren't we all?
Post by SteveHGraham » Wed Jan 23, 2019 8:22 pm
Pro tip RE overdosing on Metamucil: you're not supposed to smoke it.
Post by John Hasler » Wed Jan 23, 2019 8:28 pm
So you tried it? What was it like?
Electrojim writes:
Jigs are what you press the drill bushings into (or rather a jig is the finished result of pressing drill bushings into a plate of some sort).
Post by SteveHGraham » Wed Jan 23, 2019 9:26 pm
If it really worked, it would replace meth as the drug of choice here in northern Florida. The roads would be packed with dealers in pimped-out Mercury Grand Marquises.
neanderman
Post by neanderman » Sat Jan 26, 2019 12:07 am
I don't recommend you take it IV either; it'll really clog you up!
Ed
Le Blond Dual Drive
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
mcostello
Post by mcostello » Sat Jan 26, 2019 9:31 pm
The range of information found at this site is amazing! :)
