Suggestions for cutting fluids
EOsteam
Post by EOsteam » Mon Feb 18, 2019 3:44 pm
I have lately been having really good results on the faux Bridgeport using carbide end mills and CRC TrueTap Aqua in a spray bottle. It's a bit awkward because I'm spraying with one hand and turning the crossfeed with the other. It's time to investigate better options.
1) Is there a better system that doesn't require compressed air or a wider catchpan around the base of the milling machine? I'm not opposed to installing a wider apron around the base but will have to locate a supplier.
2) If I elect to stay with the spray bottle, is there a more economical solution available other than CRC TrueTap Aqua that works just as well?
Thanks again all,
HJ
Mr Ron
Re: Suggestions for cutting fluids
Post by Mr Ron » Mon Feb 18, 2019 4:04 pm
I think you could hook up some plastic tubing and an aquarium pump for a low pressure spray.
Mr.Ron from South Mississippi
Post by GlennW » Mon Feb 18, 2019 4:25 pm
If you are working with steel, just try running the carbide end mill dry and just keep it moving. Don't let it sit there and rub without making decent chips.
Inspector
Post by Inspector » Tue Feb 19, 2019 10:38 am
I wonder if a small garden sprayer would work. As long as the coolant was compatible with the seals I don't a reason it wouldn't.
Pete
