Small Diameter Slitting Saw
tornitore45
Re: Small Diameter Slitting Saw
Post by tornitore45 » Mon Apr 15, 2019 9:06 am
I did not even consider modifying a Woodruff cutter. Is a possibility if the shank length allow for collet depth and reach across all the fins.
ehughes
Post by ehughes » Mon Apr 15, 2019 10:34 am
Hi, Small slitting saws are used for undercutting mica in motor commutators. Available from supplies to motor rebuilders, EIS for example, but they have a large minimum order. Or did the last time i looked, may be others. We had some IIRC were HS, unfortunately destroyed in a fire. Regards, Earl
