Making a milling machine riser
pete
Re: Making a milling machine riser
Post by pete » Sat May 11, 2019 5:24 pm
Yeah with those needs I guess I'd do it the way your planning RSG. If you do pull the ram with the head, motor attached error on the side of over kill for the job. Combined there's a whole lot more weight than it looks like. The ram will only come out so far on the pinion gear since the rack doesn't go the full distance on the rams length. My guess is that's a built in safety so you can't extend the ram beyond a safe distance. Run the ram out until it touches the end of the rack then move it back in just a bit. Then pull the pinions retaining bolt and slide the ram out the rest of the way.
RSG
Post by RSG » Sun May 12, 2019 8:26 am
Thanks Pete! I did a dry fit yesterday and was able to get the column in by lifting the unit high enough (barely) I also forgot to turn the inside lip on the riser while at my friends shop the other day so I did it on my own lathe. It worked well but it showed my how limiting the size of my lathe was for something this big.
John Evans
Post by John Evans » Sun May 12, 2019 12:06 pm
I note a opening in the base casting. Can you access the spider through there ? If so how about making some bolt extensions ?? Use a coupling nut and a piece of threaded rod to extend your current bolt. Pin or tack weld rod to coupling nut ,thread rod into spider lock there with a jam nut. Your current bolt will then use coupling nut to pull the spider up to lock the turret/ram .
www.chaski.com
RSG
Post by RSG » Sun May 12, 2019 9:45 pm
That's an option John, I tapped four holes in the base of the block so I think I'm committed to that format. Good idea though.
RSG
Post by RSG » Thu May 16, 2019 4:49 pm
The riser complete and installed! Very happy with the outcome.
pete
Post by pete » Thu May 16, 2019 5:10 pm
From start to finish very nicely done RSG and the equal to a commercial product that may or may not have fit even close to as well. I can't recall ever seeing any home built version that didn't take the much easier way with a welded and machined riser.
Post by spro » Thu May 16, 2019 8:14 pm
WAY cool RSG!
Post by NP317 » Thu May 16, 2019 9:52 pm
Well done!
Glenn Brooks
Post by Glenn Brooks » Thu May 16, 2019 10:24 pm
Very impressed with your ingenuity and super professional casting and pattern making skills. Well done!
armscor 1
Post by armscor 1 » Thu May 16, 2019 11:28 pm
Good job Mate.
Post by Harold_V » Fri May 17, 2019 1:56 am
Nothing I didn't expect from one who has such incredible skill in making beautiful fishing reels.
Very well done!
Post by GlennW » Fri May 17, 2019 6:20 am
There was never a doubt that it would be anything less than perfect!
