marking tools
Re: marking tools
You can buy colorants for epoxy. Pick a good one and mark tools with that. You can get really creative and mill a small spot and fill it with color. Fairly hard to remove, at least harder than most paints.
Conrad
Re: marking tools
Machine small pockets into non-critical areas and use coloured epoxy to bond in RFID chips, then fit scanners with alarms to all exits
Alternatively just inform everyone that unauthorised taking is theft and that they will be dismissed and/or prosecuted if found in unauthorised possession of anything from that tool box
Re: marking tools
Now, now. One of my music mentors was a violist—first chair, in fact, in a famous symphony orchestra.NP317 wrote: ↑Tue Jun 04, 2019 12:45 amAs a retired violinist I must correct that statement.BigDumbDinosaur wrote: ↑Mon Jun 03, 2019 8:10 pmReminds me of the old advice about the safest place to store a violin is in a banjo case.
Use a viola case.
Re: marking tools
I love a violin and cellos. There are sounds and range which can't be reproduced. It is so active and so real that we must appreciate the younger musicians who had parents who knew as well.
