Fed up With Crummy Rotary Tools
Re: Fed up With Crummy Rotary Tools
Post by John Hasler » Thu Jun 20, 2019 4:44 pm
Mr Ron wrote:
Thu Jun 20, 2019 2:58 pm
I wouldn't buy a Proxxon. In the latest Micro Mark catalog, their Proxxon 16" scroll saw is selling for $189.99, reduced from $237.45. If you look closely, it is identical to a Harbor Freight or Wen scroll saw that sells for less than $100. It does come with a flexible shaft attachment. Proxxon tools are way overpriced IMO.
What would you buy?
RONALD
Post by RONALD » Thu Jun 20, 2019 5:31 pm
Way back, I think Dremel had their factory in a suburb north of Chicago (North Chicago?), I remember their service was very prompt and correct.
Today they are in Racine, I might think of driving that far, but I usually will buy a newer model, if it goes bad.
Google: "dremel factory store" to read about their repair facility, Google has views of the building.
I bought a Proxxon small chop/miter saw, but from a place that had a better price than Micro Tools.
With it "rubber band" drive, it kept coming off the pulley until I turned a new pulley.
It's great for cutting small metal angle, etc., but the belt tends to slip with no way to adjust tension; I would give it a 6 out of 10; the words "Heavy Duty" are ludicrous.
liveaboard
Post by liveaboard » Fri Jun 21, 2019 2:01 am
Dentists use rotary tools; if you want a good one and you're willing to pay, that's what to look for.
Otherwise, get on Craigslist / ebay and buy 4 or 5 used Dremels [or whatevever]. I think many people buy them and never use them.
Bearings? Order from a bearing stockist. Those tiny ones can be expensive, but then you have a known good bearing.
Post by SteveHGraham » Fri Jun 21, 2019 9:58 am
I may have been too hard on the new tool. Maybe it's not defective. Maybe it's just wimpy.
Post by SteveHGraham » Sat Jun 22, 2019 5:42 pm
I now have a Dumore. It arrived today. I installed the same tool that made the Dremel lose its lunch, and the Dumore purred like a kitten. It runs a Chinese (probably) burnishing tool with no complaints at all. I'm sure the tool is unbalanced and crude, and I think the poor balance is what upset the Dremel. Nonetheless, it's very obvious that a better rotary tool can deal with it.
Now I wonder if it's okay to return the Dremel. I thought it was defective, but now I think it's just an inferior tool which is probably working as well as the design and construction permit. I dirtied up one of the sanding drums that came with it, so now I feel like I'm stuck with it.
It does have some gadgetry on it which could be useful, as long as I don't overtax it.
Inspector
Post by Inspector » Sun Jun 23, 2019 10:27 am
Lots of people return tools after they use it some. If you feel it didn't meet the recommendations of a salesman or published specs then returning it is okay because it isn't fit for the job you were told it could do. If you bought it without researching thoroughly and you are disappointed then I feel it's yours. I would chalk it up to experience and keep it for the light duty stuff it was intended for.
Pete
Post by SteveHGraham » Sun Jun 23, 2019 9:05 pm
It's interesting that the Dumore handles the load better. The bearings aren't particularly large compared to the Dremel's bearings, but the tool's case appears to be steel, whereas the Dremel seems to be fiberglass. I guess a heavy metal casing makes it more rigid.
It's considerably bulkier than the Dremel, but it's worth it to have a tool that works and lasts.
