So as to not tread on another persons thread I thought I'd start a new one regarding roughing out a part prior to finishing.Harold_V wrote: ↑Fri Nov 29, 2019 1:06 am
When I machine complex parts, I handle the roughing operations pretty much the same way I handle the part in finishing. That means I'd also hold the part as you suggested, but the round diameter would not be finished to size--just roughed. When the part was roughed completely, I'd then start over, machining the round diameter first, so it would be used in fixturing, just as it was in roughing. The difference, now, is that the parts should have undergone the vast majority of change that can be expected, so the end result is all diameters and faces remain as they are machined.
For those that don't already know I make fishing reels, fairly complicated ones I'd like to think, with tight fitting matting parts and so on. I do this without taking roughing cuts while working on the lathe, my friends at a local machine shop have always used the practice and told me to do so as well. Harold and Glen W here indicated they do too. Perhaps it was from inexperience but that stems from mainly one reason, when I tried it I would get high frequency chatter so bad on certain thin walled sections that it made both the finish and dimensions change. Moving forward many years now I supposed my ability is better but have not bothered to revisit the practice and have found the outcome of my work to be more than satisfactory despite not using the practice. Currently I can reach for any part on the table and assemble a reel without having to try to mate parts together due to not fitting and it doesn't matter how many reels I'm making.
So I have to ask, would revisiting roughing out really add to accuracy of my parts or would it only add to the time.
What does everyone else do?
